Bosco heating element leak has me stumped... - Page 3
- drgary
With a much larger gasket holding the lid on my boiler with a different machine, I used a torque wrench and found that after the first couple of weeks, the hold loosened a bit, so i retightened. After a couple of months the torque had loosened and I tightened again. But you've got people on here who are much more expert restorers than me who haven't mentioned that, so let's see what they say.
LMWDP#308
LMWDP#308
- mrgnomer
I'd keep an eye on it and tighten it if needed. Depends on the metal, I think. Some metals flex more under pressure and need to be checked for bolt tightness in the beginning. My experience with alloy car tire rim lug nuts is they need to be checked after short distance and retightened to be sure they're secure. I do it atleast 3 times. If you don't know what was done at the factory torque or thread sealant wise to secure the part it wouldn't hurt checking it every now and again I think.
Stainless on brass or copper corrosion could be a galvanic reaction. Grease would treat that. Anytime there's dissimilar metals coming into contact it's good practice to wrap the threads in teflon and dielectric grease them up. I've used Molykote Dow 111 grease on connections and threads. I also use teflon tape and thread sealant paste on water connections.
Kirk
LMWDP #116
LMWDP #116
- IamOiman
The Anodic index difference between brass/copper and stainless steel (any type) is small enough to not seriously risk galvanic corrosion. That is often why I use brass nuts with stainless steel bolts or studs on my machines without the need of protection like grease. However using it for lubrication purposes during threading is perfectly fine if preferred.mrgnomer wrote: Stainless on brass or copper corrosion could be a galvanic reaction. Grease would treat that. Anytime there's dissimilar metals coming into contact it's good practice to wrap the threads in teflon and dielectric grease them up. I've used Molykote Dow 111 grease on connections and threads. I also use teflon tape and thread sealant paste on water connections.
-Ryan
LMWDP #612
LMWDP #612
