I am presently ordering a Reg Barber custom tamper for my new Pavoni Europiccola. My question is simple: what size of tamper will fit my basket best? I am confused as some posters suggest 51mm and others 51.5mm. Should I choose one somewhere in between?
J
Best tamper size for La Pavoni Europiccola Millenium - 51.0mm or 51.5mm ?
Typically, the BASKET is @ 51.5mm, I use an EPNW EP5 flat bottomed tamper that measures EXACTLY 51mm. IF you were to use a 51.5mm it'd more than likely bind as it went down inside the filter basket.
EDIT: this is for a newer system... Older,. pre 2000 systems were 49mm filter baskets.
Steve C.
I'm having an out of coffee experience!
LMWDP # 164
LMWDP # 164
so the 51mm is perfectly adequate for you?
I just want to get this right, as the cost is not negligible.
J
J
Works just FINE for me... Does all that I could ask of it!
Steve C.
LMWDP # 164
LMWDP # 164
- Fullsack
I have a 51.2 for my Europiccola and it is a little tight for low dosing in the tapered basket. Get a 51.0 or 51.1, nothing larger.
LMWDP #017
Kill all my demons and my angels might die too. T. Williams
- jamhat
My 51.0mm Thor works like a champ. Fullsack made a good point about the single basket being narrower at the bottom - n.b.
- cafeIKE
Ian's Coffee Stuff
If you don't mind the expense, you can send your basket to Reg, and he'll custom fit it.agnaramasi wrote:I am presently ordering a Reg Barber custom tamper for my new Pavoni Europiccola. My question is simple: what size of tamper will fit my basket best? I am confused as some posters suggest 51mm and others 51.5mm. Should I choose one somewhere in between?
J
I've heard that these basket varied very slightly.
EDIT...I meant the mailing expense.
- r-gordon-7
Another vote for 51.0 mm being fully adequate (in my case, for the Gaggia Factory, which has the same p/f & basket size as the Pavoni Millenium). Anything larger (or possibly larger than an additional .1mm) will likely bind, especially when low dosing or using the single...
r-gordon-7
r-gordon-7
r-gordon-7
LMWDP #188
LMWDP #188
So if I buy another basket, my $80 Reg might not fit?IMAWriter wrote:If you don't mind the expense, you can send your basket to Reg, and he'll custom fit it.
LMWDP #226.
"It takes many victims to make a culinary masterpiece"
