Back with a new project... La Pavoni Eurobar
- civ
Hello:
What's wrong with the old one?
Are all the parts there?
Has it been tested?
Best,
CIV
Besides needing a cleanup ...Buffy_ZA wrote: ... currently looking for a new OPV ...
Has it been tested?
Best,
CIV
Hello!civ wrote:Hello:
Has it been tested?
Best,
CIV
The machine works, gets hot etc..
I got new seals yesterday, all I need now is the opv.... looks to be missing the spring...
LMWDP #473
There is a spiral pipe around the boiler. Did you add it?
Nope, it was on there.
it looks factory and seems to form a part of the plumbed in option.
LMWDP #473
- civ
Hello:
You turn it on and get it to working pressure?
Please explain.
I expect that parts for it are also rare.
I have never seen one except in photos.
There are quite a few posts regarding this model here at HB.
Check them out.
Here's one: La Pavoni Eurobar Leva restoration
Best,
CIV
When you say "The machine works ...", exactly what do you mean?Buffy_ZA wrote: The machine works, gets hot etc..
Please explain.
According to F. Ceccarelli:Buffy_ZA wrote: ... new seals yesterday, all I need now is the opv.... looks to be missing the spring...
See http://www.francescoceccarelli.eu/lapav ... ar_eng.htmf_ceccarelli wrote: "Produced from 1978 to 1983, is it very rare."
Check them out.
Best,
CIV
hi,
It could well be that the spring in the current europiccola/professional OPV also fits this one. Alternatives (besides replacing it with the europiccola/professional OPV) could be the safety valve used in the la pavoni bar sytems, (see here, bottom one on the page https://www.lamacchinadelcaffe.com/en/v ... avoni.html or here https://www.theespressoshop.co.uk/Mobil ... -4562.aspx
those are rated at 1.8bars. It will depend of course on the tread used in the connection.
Cheers,
Rob
Cheers,
Rob
LMWDP #647
- civ
Hello:
A teflon/stainless stell ball of the right size?
Maybe it seals metal to metal?
No idea, never seen one of these.
Apparently there's also a pressurestat of some kind somewhere but unseen in the photos.
Unfortunately, the valve was not part of the teardown.
Maybe drop him an email? http://www.francescoceccarelli.eu/contatti_eng.htm
Could you post more phtotos so we can see what else makes up your Eurobar Leva?
ie: from behind and from below as well as the label indicating which model it is.
Best,
CIV
In this this post from 2017, it is referred to by HB member drgary as an overpressure valve.Buffy_ZA wrote: ... currently looking for a new OPV ...
It is not only missing a spring but also whatever seals the valve.drgary wrote: The small fitting this side of the boiler cap is the overpressure valve.
Here's a live link link to the mentioned teardown, the one in drgary's post is now dead.drgary wrote: Francesco's teardown of the second model shows that the pressure stat switch (PSTAT) was typically mounted below, under the heating element plate.
Here's a close-up of the overpressure valve ...
Best,
CIV
- Paul_Pratt
Cute eurobar, I have one too which is sadly in storage otherwise I could check the safety valve. The safety valve IIRC was 1/4 bsp but you should measure the OD of the threads to double check. 1/4 bsp safety valves are fairly common so not too hard to source.
Plumbed in machines usually have a fill lever on the lower right hand side.
- drgary
Thanks for spotting that. I went back and fixed the link.civ wrote: Here's a live link link to the mentioned teardown, the one in drgary's post is now dead.
FYI, on Francesco's site, he has pages that show successive models of levers, like the Eurobar. Wherever you see a link under the heading, "Description," he posts a teardown. I found the new link there.
Back to the overpressure valve, if you can't easily find a replacement, fixing what you have shouldn't be hard. All you would need is a stainless steel ball bearing that covers the vent hole in the center and a stainless spring. Tensioning is accomplished through turning the top down on the threads, so the spring doesn't need to be at an exact spec. It only needs to press the ball bearing against the hole.
LMWDP#308
LMWDP#308
