Baby Lusso pipe on bottom of boiler has a pinhole leaking water
you could try silver soldering over the hole if it is truly a pin hole, but if the pipe has corroded or deteriorated you might be better off making up a new pipe
Thats the pipe in the picture but my one has a tiny hole in it.. what is it called to order a new one or how would i replace it?
It is called a pressostat tube, you can buy it for instance here;
https://www.lamacchinadelcaffe.com/en/r ... cconi.html
I would contact the company first to see if this type also fits your machine (it doesn't have the bend though that would be easily made)
Cheers,
Rob
Cheers,
Rob
LMWDP #647
If it were my machine and a replacement tube was either hard to find or expensive, I would not hesitate to silver solder (low-temp brazing) it, providing the rest of the tube looks sound. I wonder how it got a pinhole in the first place.
Its a old machine over time a slight leak.. caused a spark in the electrical.. Right now I used JB weld to seal it and seems to work..
I do want to replace the tube..
Ok order the pipe from them.. Thanks
I reached out and they said i just have to put a bend in the pipe and it easy to do..
- bobpaule
That is a decent business, they respond to emails fast and have reasonable prices, I get my Ponte Vecchio parts there.RobAnybody wrote:It is called a pressostat tube, you can buy it for instance here;
Cheers,
Rob
Never get between a man and his ristretto, ever!
I replaced the pipe but broke one while bending it .. Second pipe i got I heated it with a torch and it bent smoothly..
Now the pressure only goes to .75 bar and only goes back on when down to zero bar..
Any suggestions? I'm ssure it is not the pressure element as i took it off to test and it still went to only .75 bar..
- bobpaule
Bad pressurestat assuming grankids cannnot hear her hissing?
