*Attempting* to Service my Neighbor's Olympia Cremina - Page 2
- coffeedog
Seals look to be installed correctly. Personally for seals, I'd go with the OEM set from Cerini. I want to say the last time I cleaned my newer Cremina, the seals looked ever so slightly thicker than your pictures - but hard to tell from photos and memory.
Steve
LMWDP #731
LMWDP #731
Absolutely good advice. Why buy arguably substandard third-party seals when the OEM are readily available?coffeedog wrote:Personally for seals, I'd go with the OEM set from Cerini.
-- Richard
Played briefly with the teflon tape but didn't like that lack of precision. Once I realized it's only $15/gasket from Cerini it was an easy choice to try that next. https://www.cerinicoffee.com/collection ... per-gasket
Headed out of town for the week and hopefully I can update with a successful repair next week. If not, I'll definitely take a video of the dripping and the deluge when I pull the lever up. Hopefully I don't see that again. Lol!
- drgary
Not arguing against using OEM parts. I've used the Teflon tape shim many times. I didn't worry about lack of precision when it consistently worked.
LMWDP#308
LMWDP#308
New seals from Cerini installed. I was so confident that I didn't even take photos. Ugh. Same issue as before. No change. So much for my comments about precision! Plumbers tape may be my next attempt.
Is there anything else I could be doing wrong on the re-assembly? I have the gaskets installed the same orientation as my previous photos. I've watched so many videos.
Here are a couple of videos of what I meant earlier when I said "deluge":
Is that what you meant? I thought water was coming out when the lever was down. What we see in the video is perfectly normal. When the lever is up water is introduced into the grouphead and will infuse the coffee in the portafilter.
- coffeedog
Your "deluge" is most excellent! The reason for the OEM seals was to address the drip during warmup. Are you still experiencing that?Marmot wrote:What we see in the video is perfectly normal. When the lever is up water is introduced into the grouphead and will infuse the coffee in the portafilter.
Steve
LMWDP #731
LMWDP #731
Ah. Well I feel kind of silly. The drip is totally gone now.
There's still a downward pressure on the piston that you feel in the lever. As if it's being pulled down. My very first re-assembly also left with the same sensation, and at this point I can't even remember the specifics, but I know the shot I tried to pull did not even come close to working.
It's early and I haven't had any coffee yet, so I'm not sure if that makes sense.
I'll heat her up and see what happens!
- coffeedog
Well that is good news! Just to be clear, the lever will normally be down (gravity, lever weight, etc.) Let us know how it goes - it certainly sounds like you are good to go!
One last thought, if it sat in your neighbor's cupboard for a long time it's possible the seals and housing might have gotten a little "tacky". When you re-lubed, it allowed the piston to move more freely, so maybe that is the difference you are noticing.
Steve
LMWDP #731
LMWDP #731
