The Arrarex Caravel - Page 221
- drgary
Thanks! What difference does rewiring make if the old 220v wires are still intact? Are the old wires more resistant and prone to overheating?
LMWDP#308
LMWDP#308
- redbone
Depends on the condition of the wiring. I replace as needed since the Arrarex is a low wattage machine the current the oem gauge wires suffice if in good non fraid or cracked condition.
They often are wired with a good quality high temp woven m.g.t or m.g.g.t jacketed wire, depending on year.
I also replace wires that are tight or short such as the wires to the element.
All porable power cords get replaced with new 3 conductor wire and new plug.
I replaced entire wiring on my Vam. It had the older ceramic beaded covered wires with some exposed spots and have replaced some Caravel machines entirely also. I don't know if that was necessary or just a practice in futility.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- drgary
Thanks!
LMWDP#308
LMWDP#308
- redbone
See here for bulb information. The Arrarex Caravelpeacecup wrote:I have this one, a 1.1:
http://www.francescoceccarelli.eu/Macch ... na_eng.htm
You can see in one of the photos the ceramic block that holds the element. Mine is cracked, and I wonder it anyone knows what to use to repair it? I also need a new light bulb. The wiring seems easy enough.
The main question is will this Vam make as great espresso as my original Caravel 1.0, or should I just sell it?
The VAM 1.1 is a beautiful machine. Squared lever arms, little boiler lever and a few other nuances that are specific to the VAM vs early Caravel.
They can be tricky to setup temperature cutoff vs the Caravel machines with the mini temp knobs. I still prefer the heavier more robust feeling VAM.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Would you say the Arrarex potentially can produce the best espresso with the smallest footprint?
- redbone
Difficult statement to make since I find different coffees do better on open boiler and some on closed boilers. I would say that it's a capable machine in the learned hands.
For the money and ease of maintenance, it's hard to beat.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- redbone
I've noticed a great temperature difference within the boiler depending on thermostat location. The temperature varies 8F higher at the back apex of the boiler vs the front by the piston. I do stir water in the boiler but this does not effect the floor temp of the boiler and has little effect.
I now go with the temperature of the water by the piston inlet holes in boiler at front since this is the first line of water that makes contact with the grinds.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- mrak
I wonder if it is possible to find an original single dose basket for Arrarex Caravel - one that holds approximately 10 gr of coffee. Both my machines came only with double baskets.
Does anybody know where I can buy one?
- redbone
