The Arrarex Caravel - Page 215
HELP. Anyone know what is the best screw material to use as a replacement to work with the Spelter base of a Vam 1.1?
When opening the bottom, I have snapped one of the plastic feet screws and I will need to drill it out/ re-tap and replace with a new screw. I assume that as Spelter is a zink alloy, a zink screw would be the most appropriate replacement to limit Galvanic corrosion
Any advice much appreciated.
- redbone
Real Name: Lost13, sounds like you're on the right track.
Don't know what the thread off hand. These are quite small. You can always go with a SS threaded rod cut to size.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Redbone
Thanks for your response.
I suspect SS would be a source of galvanic corrosion in the long run as the SS would sit against the shelter and there is no way to isolate the 2 metals.
- grog
Also, depending where the missing foot is, you can just elect to not replace. Some models have quite an array of feet on the sides, and the loss of one of these doesn't impact stability. If it's in a location where eliminating it isn't an option, you can go with the more clunky but nonetheless effective approach of gluing (or more likely, epoxying) the broken foot on. You typically don't need to remove the bottom plate for routine servicing and the epoxy/glue could easily be broken off and re-applied in the case that you do need to remove the plate. That way at least you have a stable machine.
LMWDP #514
Hello....
I started this thread weeks ago...Finally I m done....
Now if someone want to direct me where I can find good example of this beauty in 110V version I would be really grateful.
CoffeeLover32...That is amazing 200+ pages.
I hope you find your Caravel - they are a treat and will give some joy.
For me one of the best things is that a Caravel can give some great results with less than stellar beans (yes even supermarket beans). Of course this machine will reward you when you have great beans.
- redbone
Impressive work, I recall doing the same a while back before taking the leap to ownership.CoffeeLover32 wrote:Hello....
Original 110v machines are hard to come by. Many were converted as the elements are available and the conversion is quite easy with some minor electrical knowledge.
Currently there is a 110v for sale in the buy / sell forum here. Best of luck and happy hunting.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Thank you redbone it was a journey....redbone wrote:Impressive work, i recall doing the same a while back before taking the leap to ownership.
I cant find any available in the buy/sell section all of them are sold ,probably I'm missing something
- redbone
Looks like it sold recently. You can always find one via ebay Italia and convert the electrical cord to 110-120v if comfortable. I would also replace any suspect internal wiring with new high temperature wiring. Elements are available from Brooks and at times via Paul at Cafelat. Brooks is in the Netherlands and shipping is expensive. If in no rush they do come up on the market here.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Yea that would be my route I ll search for one here if nothing comes up I will grab one from ebay
