The Arrarex Caravel - Page 223
peacecup
Postby peacecup » Feb 15, 2018, 4:34 pm
Wow! That is a beauty. I hope it treats you well.
LMWDP #049
grog
Postby grog » Feb 15, 2018, 4:56 pm
Very nice example. What basket(s) came with it?
LMWDP #514
crazy4espresso
Postby crazy4espresso » replying to grog » Feb 15, 2018, 9:49 pm
It came with one single basket only. I only had double baskets so this was a plus.
"I would rather suffer with coffee than be senseless." — Napoleon Bonaparte
LMWDP #427
grog
Postby grog » Feb 15, 2018, 11:42 pm
Very cool...the single baskets are much rarer.
LMWDP #514
redbone
Postby redbone » Mar 22, 2018, 11:53 am
VAM back on rotation.
Interesting observation, from a cold start I noticed a temperature variance of 6f within the boiler. The inside back of boiler was 210f while front near the inlet holes was 204f. This temp variance was closer on the second shot 3f. I pass a blank heat up shot prior to initial pull in order to heat components and demitasse cup.
* I use a fast acting thermometer called Thermapen by Themoworks. Fast sensing and accurate.
Semper discens.
Rob
LMWDP #549
redbone
Postby redbone » Jun 14, 2018, 7:38 pm
Latest Caravel a 1.1
A 24hr soak followed by 30min ultrasonic cleaning and scrub with Barkeepers Friend.
Some fine steel wool also used on piston parts, screen and portafilter.
Time for some rewiring and cord replacement.
Semper discens.
Rob
LMWDP #549
redbone
Postby redbone » Jun 15, 2018, 4:58 pm
Rewired, de-scaled, new silicone seals and high temp thicker gauge wiring.
Upgraded silicone seals.
Semper discens.
Rob
LMWDP #549
doubleOsoul
Postby doubleOsoul » Sep 12, 2018, 9:03 pm
My Girl Arrived! It smells like Italy in here ...
I almost posted in the roll call thread but wanted to rap a little about what comes in the box with what I'm guessing is the third version Caravel. This is another old new stock Caravel and while I wasn't really looking for another, the Caravel canister was a collectable I was looking for. And for some time too. It was interesting that it was packed in the box like it was part of the Caravel set and made me think that it would have been originally (okay, I might be reaching here). The original tape is on the drip tray so another clue that this lever has been completely untouched and that a canister would have been a likely candidate for these later model Caravels. One thing I'm a little confused on is the pf baskets. There are 2 but then there is one in the pf holder that I can't remove (unless I just need to add more muscle or intention :shock: for removal - one of the two). This is also what I discovered with Big Bird, viewable in the background. I thought it was glued in the pf holder from mid century modern dust and coffee tar or as I like to call in my business - coffee essential oil but are they even removable? Maybe Francesco would know a little more since I saw on his website that he sold a canary (sans coal mine) yellow 1975 Caravel a little while back.
Ways to win my heart:buy me coffee, make coffee, be coffee LMWDP #354
★ Helpful
drgary
Postby drgary » Sep 13, 2018, 1:49 am
As I've already shared with Cher offline: :shock:
It's got to be removable. Is it a tight twist out held in by a small dimple in the filter basket?
LMWDP#308
grog
Postby grog » Sep 13, 2018, 9:57 am
I had a basket/PF situation like that with a Caravel. They are held in by a small dimple (Arrarex's version of a ridged basket I suppose). I found twisting it out by hand impossible at first, and was worried about damaging it with metal tools.
Finally I thought of using a small bamboo skewer, by putting it into one of the holes in the bottom of the PF and tapping the other end of the skewer on a counter top. That popped it out without any damage to the basket.
I had to do that several times. After it's been in and out a few times the pressure fit loosens enough that it still stays on place but you can pop it out by hand.
LMWDP #514
