The Arrarex Caravel - Page 209
- redbone
Thanks, Max since cut away a conical frustum on each side.dumpshot wrote:I think it looks great! Nice work.
Pete
Each of them is 1/8th of the total width.
Better fit when butting against the metal end pieces allowing for handle rotation.
Here it is being created in process.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- redbone
I'd have to call this kit complete. VAM 1.1 with Caravel canister and accompanying grinds spoon.
One off machined tamper. Red 3D printed funnel designed by member Max from Switzerland.
Grill out of the picture. I placed the grill off to the side so I can fit my taller espresso cups.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- grog
I've had two VAMs and both have been the 1.0s with the dreaded 'no-hole' piston. The 1.1 to me is the best possible Arrarex - VAM build quality with the superior piston configuration.
LMWDP #514
- sosha
Love it! Redbone, can you tell me how to replace that part on the handle ? I got a replacement, but can't figure out how to replace to old one.....
Thanx!
Patty
Thanx!
Patty
LMWDP #440
www.kelpfish.com
www.kelpfish.com
- redbone
It was a P.I.A. crazy4espresso (Nelson) has a nice pick\pointy chisel set and performed some magic on a visit to his place.
It involved soaking in penetrating oil and knocking out pin with hammer and metal pick\round chisel. Plenty of elbow grease needed.
Except for cost don't why they didn't go with a small set screw solution.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- redbone
I like the heaviness of the VAM's but find the early Caravel's 1.1 & 1.2 to be the most temperature stable once dialed in. The edition of the little metal temp knob makes for an easier and more percise setup than the VAM's.grog wrote:I've had two VAMs and both have been the 1.0s with the dreaded 'no-hole' piston. The 1.1 to me is the best possible Arrarex - VAM build quality with the superior piston configuration.
Past 1.2 the quality and features dropped including the removal of the boiler knob which was replaced with a push lever. Tried a 1.3 and noticed a marked difference.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- sosha
OK, then. Guess I'll just stare at the replacement for a while. Love love LOVE the flavor in this little shot!redbone wrote:It was a P.I.A. crazy4espresso (Nelson) has a nice pick\pointy chisel set and performed some magic on a visit to his place.
It involved soaking in penetrating oil and knocking out pin with hammer and metal pick\round chisel. Plenty of elbow grease needed. Unknown except for cost why they didn't go with a small set screw solution.
LMWDP #440
www.kelpfish.com
www.kelpfish.com
- redbone
Well if we were not passed the 49th I'd say mail it.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Hello again everybody!
I managed to choke my Caravel today, switching back to Woseba blend from a nice single origin.
@Pafcio0, I noticed you are too from Poland, what city do you live in? From the out the window view in your video I could make a wild guess you are from a certain part of Łódź...
pafcio0 wrote:This Caravel still works as a charm, and my routine is more/less the same. 2 cappuccini every morning (which takes me not more than 5 minutes overall) + some espressi every afternoon for about 2 years so far. The setup has changed a little - monstrous Fiorenzato F6 took the place of Eureka. Deffinetely not thinking about any other machine so far
'a a ha sha sa ma!
LMWDP #199
LMWDP #199
- doubleOsoul
Robert, I'd be lyin' if I said I wasn't a little jealous. Good accessory score!redbone wrote:I'm waiting on this Caravel container to pair with my Arrarex machines.
I like the nostalgia of it.
<image>
www.soulsidecoffee.com LMWDP #354
