Argos lever espresso machine by Odyssey Espresso - Page 27
Jake_G
#261: Post by Jake_G »
Sorry for my useless response.
I too ordered both. I ordered with the 8 bar installed and got the extra piston assembly along with a 6 bar spring. Many others have followed suit as you and I have and ordered both, along with a spare assembly.
LMWDP #704
Jeff
#262: Post by Jeff »
I unhesitatingly ordered both springs based on my experiences with coffees tasting different at different pressures. I haven't decided on a spare lever, especially since the changes to make the switch-over easier.
Amberale
#263: Post by Amberale »
I did the same Foamy.
I have a CT1 so I will probably run the Argos as a springer.
boren
#264: Post by boren »
foam2 wrote:I originally ordered it with the 6 pound installed and understand it is easy to switch out but curious what others were doing.
I wonder how easy it is to switch the spring on the Argos. With machines like the Elektra MCaL people have to build dedicated jigs to replace the spring. Not something I would describe as easy.
Jake_G
#265: Post by Jake_G »
No need with Argos.
When the piston is removed from the bore, the spring is loose.
LMWDP #704
Ah_J
#266: Post by Ah_J »
Ordered both as well to integrate a full lever system with my Cremina 87
bgn
#267: Post by bgn »
My original order was for an 8 bar spring. Last week I ordered the 6 bar spring and the manual pressure gauge.
Felice
#268: Post by Felice »
As an aside, I changed my MCAL spring easily with a larson clamp.
boren
#269: Post by boren »
Interesting. Do you have a picture of that setup?
baldheadracing
#270: Post by baldheadracing »
Felice wrote:As an aside, I changed my MCAL spring easily with a larson clamp.
I don't have to use a clamp at all; I just unscrewed the piston (pre-1997 assembly). The only time I needed a clamp was to put an initial set on a new post-1997 spring (before installation).
(I would assume that the Argos springs are supplied with a set.)
