Announced: Argos lever espresso machine by Odyssey Espresso - Page 18
First lever was a La Pavoni Professional. A Flair Signature Pro which I use for travel. An Izzo Valexia and now of course the Strietman CT2. I have the Argos and a Nurri Lava S.A. on pre order. (I have a DE1XL, a Portapresso also). My favourite is without question ismthe Strietman. My preferred style is a thick medium to dark espresso and I find that with the right puck prep the Streitman delivers every time.Tjyven wrote:Off topic but curious which lever machines you owned? Interesting to see what users think of their machines.
A little obsessed.
Really interesting, even though I find the Strietman rather expensive it sounds lite it is worth it. Will be interesting to see how you compare it with the Argos and Nurri. Btw, you prefer it over the DE1XL too?
Would this still be the case with open boilers like the Strietman and Caravel?pizzaman383 wrote:The problem I am talking about is that going slow as the piston just starts to open the hole can cause a downward jet that disturbs the pu k. This is somewhat dependant on the seal, piston, and shower screen geometry.
Agree it will be interesting. And yes, I like the DE1Xl a lot but I am in love with the StreitmanTjyven wrote:Really interesting, even though I find the Strietman rather expensive it sounds lite it is worth it. Will be interesting to see how you compare it with the Argos and Nurri. Btw, you prefer it over the DE1XL too?
A little obsessed.
Amberale you old rogue. Hello again. Don't know about the Carvel but with the Streitman it's not an issue so long as you take 4 to 6 seconds to lift the lever.Amberale wrote:Would this still be the case with open boilers like the Strietman and Caravel?
A little obsessed.
- pizzaman383
- Supporter ❤
I don't think so. It is water coming in at high pressure but open boilers don't feed such high pressure.Amberale wrote:Would this still be the case with open boilers like the Strietman and Caravel?
Curtis
LMWDP #551
LMWDP #551
PS I'm not suggesting that the Streitman is better than the DE1. The latter is a remarkable machine and probably the ultimate for trying different styles. So please take my preference in the context of my preference for medium/dark roast thick syrupy style espresso
A little obsessed.
- yakster
This is one reason I may pick up a puck screen if I start using my old Faema Faemina lever again.pizzaman383 wrote:The problem I am talking about is that going slow as the piston just starts to open the hole can cause a downward jet that disturbs the pu k. This is somewhat dependant on the seal, piston, and shower screen geometry.
-Chris
LMWDP # 272
LMWDP # 272
Moi???tompoland wrote:Amberale you old rogue. Hello again. Don't know about the Carvel but with the Streitman it's not an issue so long as you take 4 to 6 seconds to lift the lever.
I was trying to be subtle.
In truth, it shall be interesting to see what work-arounds and extras work best with the Argos with its 58 mm group.
I am really enjoying my foray into smaller diameter lever groups( Caravel and CT1) but also looking forward to playing with the Argos.
