Anyone heard of a La San Marco 52 3 lever - Page 5
- drgary
I'm very glad to see this and look forward to seeing you bring it back to life.OldAndBigTr3E wrote:Thank you for all of the input. Im going to keep it and see if i can get more details about it and find parts. Got it to my house just need to get it on the work bench. I think i also may clean it after all, i would really like to see it shine. Thanks again everyone
LMWDP#308
LMWDP#308
I have started to clean it up, i will post pics when it is all clean. And if anyone was wondering this unit is 39 inches wide and 18 inches deep. I was looking at Enrico's 42 and was wondering how that group is supposed to opperate with the knobs(no levers)?
LMWDP#587. Pull the lever to claim your prize.
In the pre-levergroup-era coffee was brewed on this machines using steam pressure. Thus a coarser grind was necessary and the coffee was rather "burned" than brewed
Also there was no such thing as "crema" on these cups - that only started with spring assisted levergroups: higher extraction pressure, finer grind, lower extraction temperatures allowed the etheric oils to survive the group and from then on advertising as "crema caffe" started
LMWDP #422
Alright so its when the lever system was introduced espresso went from just a quick way to brew to what we know today as espresso, rich and flavorfull. Is that correct?
In a nut shell yes. The product became more consistent and controllable using mechanical pressure to push water through the puck rather than steam pressure. Initially that was lever and now mostly pump pressure.
- grog
What are you using to clean the chrome? There was a recent thread about just that topic. I've had very good results with 0000 steel wool. Won't scratch chrome and removes oxidation while also polishing. Then you can go over it very gently with Brasso or similar.
LMWDP #514
