Any way to prevent portafilter from popping off on Elektra Microcasa a Leva?
I created a thread in the past about this issue but nothing helped. Currently I'm using the machine as a (very expensive) milk steam and brewing with a Flair Espresso Maker. Is my MCaL destined to be nothing more than a milk steamer, or is there something I could actually do to fix it?
Without being there, there is no way to tell why it is really coming loose... My McAL used to do that too. I can offer only
these observations:
Again, mine came off a few times in the beginning. At first, I just held the portafilter with one hand and pulled the lever
with the other hand. I mean, you are not going to steam milk while it is extracting. After a while, I noted that when I put it on
tightly (I mean tight), it did not come off in my hand again. Since then, I have never held it while extracting a shot.
Let me define tight. I have to hold the base of the McAL while tightening it, or it will turn the machine. I tighten mine
right up to that point where I am forcefully holding the machine down on the counter thinking "this is obviously too tight".
That's about the right spot.
Hope that helps some.
these observations:
- Ensure your group to portafilter gasket is clean.
- Ensure your portafilter top ridge is clean.
- Are you locking it in tightly (this was my problem, I was scared to put it too tight). Remember, it is only friction holding it in.
- Is your grouphead pressure too high (e.g. are you grinding too fine?)
I was actually steaming while brewing in the first 5 years I had the machine, and didn't have any issues.
I like your description about getting to the right tightness. I'll try that and will also follow your other suggestions.
Thank you so much!
Thank you so much!
- sweaner
Why not just hold the portafilter handle during the pull?
Scott
LMWDP #248
LMWDP #248
I prefer to have both hands free while brewing so that I can steam the milk without having to wait for the shot to finish.
I also had an issue with the portafilter popping off in the first month I owned it. I started tightening the portafilter way more (holding down the base as described in a previous post). Haven't had the issue since.
How old and used is this cranky Elektra? Apart from badly worn lugs or head the only reasons the P/F will/might pop out is a worn or wrong gasket or not being in tight enough. Can you try another portafilter?
Just as an aside. I had a Semiautomatica that did the same thing. It also had an o-ring type gasket which looked and felt fine but problem solved by replacing it with a new gasket.
"24 hours in a day, 24 beers in a case. Coincidence? I don't think so."
I bought the machine 7 years ago and the problem started 2 years ago. The gaskets were replaced, but this only helped for a limited time. Maybe I should look for wider/thicker gaskets that use the same diameter (to increase friction)?
- peacecup
I have had the problem with my Sama, and I also like to steam while the shot is pouring. A new gasket should help. If not, you may need a thicker one.
But I also now usually hold the pf at the start of the shot, and begin steaming once the shot is about half done.
LMWDP #049
