Any way to prevent portafilter from popping off on Elektra Microcasa a Leva? - Page 2
@peacecup - are you aware of a store who sells thicker gasket? I would definitely prefer one over what is normally used for this machine.
My my portafilter used to pop off occasionally. But since I switched to a naked portafilter from naked -espresso it hasn't happened once.
This is the response I received in email from Elektra:
You can try to contact our current distributor at this direction:
[Distributor name]
For your information we do not have different (thicker) gasket sizes and from our experience we can suggest that the problem you described can be because of:
- Dirt or coffee residues on the group which prevent the correct closing of the portafiler
- Worn-out gasket
- Thinning of the portafilter "wings" due to the intense use and the age of the machine which no longer have a good grip.
Hope the dealer can help you, maybe by providing a new portafilter as it may be the cause of the problem.
I would definitely look at the ears or wings on the portafilter itself and see if they are worn or warped.
Hello everybody. Similar problem happened to me recently - please see more here:
Elektra Microcasa a Leva - Portafilter "explosion"!
Should we unite the two topics?
