ACS Vesuvius Evo Leva - Page 54
Very responsive, esp to email
They are active on forums too, there a family run team I believe.
wow, you are not wrong. I sent them an email asking if they had distributor or retailer in Hong Kong, 24hrs later, Maria @ ACS already responded with a lot of details. ImpressiveCuprajake wrote:Very responsive, esp to email
Picked up a local bean, as I've run out.
It's more a traditional roast so thought when in Rome
First dial on the niche at 18, group at 90 boiler 98, 16.5g dose
Hello there !!
So, couple of months ago my friends & I were working on a mod to lower the max pressure of the evo.
We did 3 mods which all effected the pressure.
1st one was an OPV placed under the group head which set to dispose and pressure above 9 bars. ( Two main springs was installed)
Pros: easy to adjust from 6 - 10.5 bars
Cons: you need to modify the existing cap / lost on water volume which led to fast pressure drop
2nd a spacer for the main spring to add more tension to it ( from 7 - 8 bar) ( only the main "big" spring was installed)
Pros: Bar can be changed based on how many spacers you install.
Cons: more spacers = harder job & dangerous to handle
3rd simply do a new secondary "small" spring
Pro: easy to install reliable results
Cons: hard to manufacture
We are 3 owners and we currently using the last mod and testing the difference in taste, until this moment we are enjoying the 8 bar far more than 10.5 or 6.5 from the stock springs.
Personally, I can say the body is more balanced and shots are much smoother.
Same here. I am using this stainless steel spring from Gutekunst Germany as inner spring, giving a comfortable 8 bar and a bit max pressure. I want to send one to Paolo so he can check it out.
https://www.federnshop.com/de/produkte/ ... 313ja.html
NelisB wrote:Same here. I am using this stainless steel spring from Gutekunst Germany as inner spring, giving a comfortable 8 bar and a bit max pressure. I want to send one to Paolo so he can check it out.
Hi,
first of all, thanks for the hint!
I just installed this spring and it gives me 7,5 max. Any ideas, what I could have done wrong?
Thanks! Seb
At what point does your lever catch the puck resistance? If it catches fast (low) the springs are pressed more than when your lever catches puck resistance late (high). The lower the lever catches resistance, the higher pressure from the springs. (sorry, I don't know how to explain in English).
A good test would be using a blind basket, but you won't be able to release the pressure. So, please don't. You could try to grind too fine.
