ACS Vesuvius Evo Leva - New User Questions - Page 3
Cuprajake
#21: Post by Cuprajake »
This is a 58mm tamper with a 54mm base the top hat has a lip that sits inside the basket on a normal 58mm
This lip doesn't go inside a 54mm basket and it's too thin to shave down so it would. I thought of that as I've had tampers turned down before
Amberale
#22: Post by Amberale »
I reckon there is enough meat in the top to trim it down to fit.
If not, I'll have to start with a chunk of SS and replace it.
What was the fit like for the 54mm base?
A bit loose?
Cuprajake
#23: Post by Cuprajake »
cant remember sorry bud
DaveC
#24: Post by DaveC »
The tamper the OP has I was using with standard baskets and it fits fine (my fine). Any tighter and they get a bit "catchy" when your working and after 30 or so espressos they become a PITA. The standard supplied tamper is almost at that point, but not quiet. I personally don't want it fitting too tight.
I wasn't expecting the micrometric precision requirements and suggest it won't make any difference to the extraction.
mynameisroz
#25: Post by mynameisroz »
Cuprajake wrote:Evo is getting the same features too.
I heard some features from Vostok might trickle down to Evo eventually. Is this confirmed from ACS? Any other updates worth mentioning?
5ONEohhh
#26: Post by 5ONEohhh »
I have emailed them and they told me that the rotary pump and the dosed coffee system will trickle down to the evo leva
macaber8 (original poster)
#27: Post by macaber8 (original poster) »
DaveC wrote:The tamper the OP has I was using with standard baskets and it fits fine (my fine). Any tighter and they get a bit "catchy" when your working and after 30 or so espressos they become a PITA. The standard supplied tamper is almost at that point, but not quiet. I personally don't want it fitting too tight.
In my opinion, it is all about the experience. A loosely fit tamper and basket is definitely not a good one.
Cuprajake
#28: Post by Cuprajake »
A free tamper :D
Stock tamper is fine for the stock baskets. Most move to ims comp baskets which need a bigger size.
The whole package you get is quite good really when with other machines you will only get one portafilter
fat862
#29: Post by fat862 »
If the same features trickle down, what would be the point of the Vostok - size of the boilers/cafe use? Have my eye on that machine but if all the same features would come in a smaller form factor that may be the move.
Amberale
#30: Post by Amberale »
I have the space and prefer the look and stability of the larger commercial chassis.
