49mm Tamping Station?
bovinecrusader
#1: Post by bovinecrusader »
Saw a couple old threads here, but found nothing definitive.
Aside from the RöstHaus, is there any other options for a tamping station for 49mm portafilter?
Very aware that using a bottomless helps, but even when using that I'm not able to get a level tamp while resting the handle.
Or just resign to puck prep with basket removed?
baldheadracing
#2: Post by baldheadracing »
bovinecrusader wrote:Aside from the RöstHaus, is there any other options for a tamping station for 49mm portafilter?
https://www.tidaka.net/Tamper/Tamperstation---2_5.html (use Google Translate)
You'll have to measure the outside diameter of your particular portafilter.
bovinecrusader wrote:Or just resign to puck prep with basket removed?
That's what I usually do for 49mm machines - I've removed the springs from all of my 49mm portafilters. I prep baskets due to cleanliness and/or heat management issues.
