1st Gen La Pavoni Europiccola with 3 way toggle
- redbone
First gen LPE came with toggle 2 way switches hi / low only until 1974.
After that time LP switched to 3 way rocker switches adding an off in the middle position.
The cut outs on the bases for the switches were either round for the toggle or rectangle or the rocker making them non interchangeable.
I found a 3 way toggle with off option that allowed for the original Italian max/min emblem which I like.
Here is the almost completed 1973 LPE.
I'm waiting for an adapter in mail to add pressure gauge
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Do you have a link to the switch you used? My original 2 position switch just broke and I was looking to do the same with adding the 3 position switch.
- redbone (original poster)
This is the one I used.
EDIT - Do not use switch shown below. They fail under heat and electrical stress. Melting and possible fire hazard.
Tested two switches just in case one was defective. FAILED SECOND TIME
I do not believe the Ebay resellers claim of 15 amp rating on these switches.
http://www.ebay.ca/itm/12V-Metal-Toggle ... SwWxNYxip7
Shipping from China / H.K. takes forever then some.
**DO NOT BUY SWITCH BELOW AS REPLACEMENT**
F.Y.I. 800 watts = 1.07282 H.P.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
After some extensive research I've found a proper toggle switch that meets and exceeds a replacement for the OEM 2 way switch.
Carling Technologies DC221-BB-B ON-OFF-ON (non-momentary) SPDT, Quick Conn, 20A 1.5HP 125-250V AC, Mount with Threads, Bat Lever style
Tried searching the OEM silver colour but the DC221-B-B-B best suited the requirements and is available in only black or white.
Feel free to add any others that meet the requirements of bat toggle SPDT, 15-20 Amp, 1.25+ HP, On-off-On, heat resistant min 185f \ 85c.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
The ebay model looks like a very cheap clone. Given that it's a resistive load, I would think that any high quality, certification marked, name brand 20A SPDT toggle switch would be fine. But about 4x the price.
For example, an Eaton XTD2B2A or XTD2B1A. Or even 15A is more than needed.
Most toggle SPDT (3 prong) switches are 10-15 amps at 125v and not easily available. DPDT (6 prong) toggle switches are more readily available in 20 amp options.jonr wrote:The ebay model looks like a very cheap clone. Given that it's a resistive load, I would think that any high quality, certification marked, name brand 20A SPDT toggle switch would be fine. But about 4x the price
The NKK S3AW silver bat toggle switch is another SPDT on-off-on HD option but costs more than the Carling Tech switch.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Installed Carling Technologies DC221-BB-B ON-OFF-ON (non-momentary) SPDT, Quick Conn, 20A 1.5HP 125-250V AC, Mount with Threads, Bat Lever style.
Highly rated switch in order to handle 1.5HP
Original colour base in very good condition.
View of switch inside under base with spade connector ready for wires.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- grog
Did the Carling work? This is just an aesthetic swap?
LMWDP #514
