1957 Urania 2nd gen refurb - Page 8
The dome sits inside of the scaldatazze tray. It is fastened with 6 screws, and the grid rests on top of the screws.
The entire tray fits onto the main body and lifts on/off for easy access to the boiler and internals.
I believe there are a few configurations for the dome/body depending on the model. Do you have photos of yours?
Sure, I know how it fits I was just wondering how you got the dome to fit since it did not initially. Mine is missing the little knob for the grid.mingiunate wrote:The dome sits inside of the scaldatazze tray. It is fastened with 6 screws, and the grid rests on top of the screws.
LMWDP #483
Ahh - I think @TCM (a few posts up) was the poster having trouble with the replica dome fitting. All of ours are original.
- espressotime
When you pull the lever does the machine tend to tip over?mingiunate wrote:The new spring might lean to the stronger side:
The original spring was 42m OD, ~125-130mm length with 6-6.5mm wire.
The new one is an Astoria/CMA/Bezzera ~45-46mm OD, 130mm length, 6.5-7mm wire.
I think an exact replica would need to be custom made, but its irrelevant since this group doesn't have the pre-infusion plunger mechanism that would require the more narrow 42mm OD spring. In either case, the coffee tastes great.
indeed, not even a bit and also not when you put some weight on the lever when it;s down
LMWDP #483
- espressotime
Ordered the Astoriasping and installed it in my Lambro.A little bit stronger than the original spring. Great shots. also.
