Really necessary to toss espresso after backflushing?
Is it necessary to make an espress (just to dump it) after backflushing? Reason I ask, is I flush a lot of water through the group head, even steam wand after cleaning, so why waste precious beans? Thanks.
It's only necessary to put coffee through my espresso machine in the morning when I wake up.chanty 77 wrote:Is it necessary to put coffee through your espresso machine after backflushing? Reason I ask, is I flush a lot of water through the group head, even steam wand after cleaning, so why waste precious beans? Thanks.
Seriously though, backflush away and call it a day.
Von meinem iPhone gesendet
- Jeff
Just to make sure this isn't misinterpreted in the future, one should never run liquid coffee though a machine instead of water.
I think perhaps I should have written that I put coffee through my portafilter. Definitely not through the machine!
- lancealot
Making sure I understand:
You backflush your machine. Then you make a coffee. Then you toss the coffee. And now the machine is ready to go.
Did I get that right?
If so, then no, you don't need to do that.
Just backflush your machine.
If you backflush your machine with detergent, then you will want to do a few clean water backflushes to make sure the detergent is gone. Now you are ready to make delicious coffee that you do not need to throw away.
Directions for Cafiza backflushing;
Backflush - Insert blind filter in portafilter and add up to 1/2 teaspoon (3 g) of Cafiza Powder.
Insert portafilter into group head. ...
Repeat 5 times. ...
water from group head. ...
Repeat step (2) without Cafiza Powder 5 times.
Make and discard a cup of espresso to ensure no residue remains.
Please see my correction of what I was 'trying' to say.....Jeff wrote:Just to make sure this isn't misinterpreted in the future, one should never run liquid coffee though a machine instead of water.
Thank you....YES, that's what I meant. Good, it seemed a waste of beans especially after running the pump with no detergent a number of times.lancealot wrote:Making sure I understand:
I found the discarding of espresso instruction hard to believe and had to see for myself...
I can't see how this would be necessary, especially after such an extensive water rinse. I only use Cafiza once a month, but still wouldn't waste a shot!
However this advice seems to contradict their video, which strongly implies the post-cleaning shot was consumed:
- Jeff
After a back flush with Cafiza I'll scrub the screen with my brush. Then I'll run a series of "clean water" back flushes with a blind basket. I'll typically run water though the group without a PF in place for a while and scrub the screen again with my rinsed-out brush. Last thing I want is Cafiza flavor in my first shot of the next morning!
