Processing coffee cherries at home - Page 2
- TomC
Yup, that's pergamino. You'll need to hull it first.
Kinda like wet grass. I took a sample and microwaved it until it stopped getting lighter, and it appears to be about 26% moisture, which is too high. So first thing I did is spread it out in the lid of a storage container where I'll let it dry for a while. After that I'll figure out how to remove the parchment.
When the beans are dry[er] and shrink a bit, a space will develop between the bean and parchment, so it will be much easier to strip away, leaving just some silverskin on the bean that will become chaff when you roast it. BTW, that's great looking parchment. Dry carefully, as lots of bad stuff can happen if you don't...like musty mold/fungus overgrowth.
Any tips on how to dry "carefully"? Right now I just have it spread out on the lid of a storage container, closed up in a spare bedroom where it's safe from the cats (who would probably think it was a litter box. gross). Outside isn't a good option right now because it's been cold and rainy lately.
Perhaps a fan is a good idea. It's what I use to dehydrate other food, like mushrooms.
Good call, I can probably point a fan at it easily enough.
An important thing to care about when drying the beans will be facilitating the removal of moisture, thereby minimizing the risk of mold and fungal growth on (and into) the beans. Sunlight with good air circulation works great, but any set up that allows moisture to evaporate and get removed from the beans should work. The recommendation to use a fan is good.
