Has anyone tried this 20A Wi-Fi outlet?
Hi,
I have seen some other posts of similar products but have not seen anyone discussing this particular one, which seems relatively new. Does anyone have a view?
https://www.amazon.com/ConnectSense-Con ... 081ZCTHH7/
Like many of you my espresso machine (ECM Synchronika) can heat both boilers simultaneously when on 20A power. Also like many of you I want to use a smart timer of some sort to turn the machine on and off for me each day.
I do have a 20A circuit in my kitchen and currently have a 20A outlet with the T-shape on one side. I would prefer to use a "smart plug" and have a few of those already, but none are rated for 20A and I don't want to risk frying one.
I realize it's somewhat expensive, but seems like the only option I can find, unless someone else has another idea...
- Balthazar_B
Jon, I haven't used the ConnectSense product -- way back when I wired in the only 20a smart controller available at the time -- but it's UL-rated and the reviews on Amazon are pretty good, so IMHO it would be worth a try, especially since you can return it to Amazon if it doesn't work as advertised. Assume you've already confirmed that the wiring on your current outlet is proper from a gauge standpoint for supporting 20a.
- John
LMWDP # 577
LMWDP # 577
- cerone
I wanted mine to be z-wave compatible so this is the one I'm using on my Lucca M58. Works great! No issues at all.
https://www.amazon.com/gp/product/B00MBIRF5W/
I have a synchronika and I use the 15 amp outlet below. Nice app with schedules etc and it has worked well.
https://www.amazon.com/Kasa-Smart-Outle ... 07N3CK3MM/
- Balthazar_B
That's what I've been using since 2017. Works very well, but depending on how Jon's outlet is wired -- mostly whether he has any access to it between the receptacle and the breaker box -- it may or may not be feasible for him to consider. Fortunately I was able to intercept the dedicated 20A wiring in an accessible location and have been pleased with the Aotec's operation.cerone wrote:I wanted mine to be z-wave compatible so this is the one I'm using on my Lucca M58. Works great! No issues at all.
- John
LMWDP # 577
LMWDP # 577
Thanks for the feedback. I don't think I can interrupt to insert the switch within the wiring, so I think I will try this Amazon outlet. I'll let you all know how it goes!
Just purchased myself a QM Vetrano Evo 2B, and am wondering if people have had success with any smart outlets on 20A?
The Connect Sense (https://iot.connectsense.com/products/in-wall-outlet) seems like it might work - and I've heard that the power is actually 2400W for to 20A, not 1800W.
All help is appreciated, thank you!
- BaristaBoy E61
If our Wemo gave out I would definitely give this a shot! However, with the time it takes me to pull a shot I seriously doubt a 20-amp outlet would make any difference.
I'm looking specially for 20A because that is what the machine is rated at, with both steam and brewer boilers working at once.
Thanks#
Thanks#
