The effect of espresso drinking on cholesterol
- drdna
Should I give up espresso?
The concentrated aromatic oil fraction in French Press coffee and the corresponding crema in espresso may contribute to elevations in "bad" LDL cholesterol and depressed "good" HDL cholesterol, as described in various studies.
Well, I recently got my cholesterol checked and it was a whopping 238. Not good at all. I already exercise about four or five times a week and eat a vegetarian diet. The only dairy product I consume is the milk I use to make my cappuccino.
I love espresso, but I am seriously thinking I should quit if it is going to affect my health.
Adrian
- howard seth
Perhaps, You may want to see a Doctor about your cholesterol level. There are various medications (Statins) to lower your LDL level, and raise your HDL - as you most likely know. I checked your "study" link - seems you have to drink a lot (5 cups) of French Press coffee each day to raise your cholesterol level 6-8%... but you would still be over 200, however if you cut out coffee ...
I also think you might look into other research about the coffee/cholesterol connection further; I would be interested in what you might find. Some claim health benefits to coffee consumption.
Howard
Howard
Howie
- drdna (original poster)
Yes, I got the information when I saw the doctor actually. He suggested a statin, but I would prefer to find a natural way to lower my cholesterol. It seems to me that the human body is a finely tuned mechanism. If it is not functioning properly (given no infection or genetic defect)then you are not doing something right in terms of diet and exercise. It is true that drinking coffee can be healthy and that drip coffee using a paper filter eliminates the cholesterol effect.howard seth wrote:Perhaps, You may want to see a Doctor about your cholesterol level.
But that would mean trading in my La Spaziale for a Technivorm and I am not sure I am up to that.
Adrian
I happen to be a nutritionist/educator and cholesterol is one of my specialties. Your main concern in raised LDL levels and triglycerides is saturated fats, more specifically long chain fatty acids (LCFA). You won't get this from coffee oils, as most LCFA come from animal and man made fats. An additional consideration is total cholesterol numbers are not the most important number to pay attention to; LDL, triglycerides, and your cholesterol ratio are much more important. In short, your other lifestyle habits are more likely attributing to your cholesterol woes than your espresso. This is of course without having a full assessment of your eating/fitness/tobacco usage habits. Maybe you can use a lower fat milk in your caps?
- JohnB.
Depends on your system I guess, I saw my LDL levels drop 20 points between 2/08 & 2/09. During that period I drank only unfiltered coffee & Espresso on a daily basis. Is this the first time you've had your levels tested?
LMWDP 267
As I mentioned, I eat a strict vegetarian diet (actually vegan except for the milk in my cappuccino) and exercise 4-5 times a week. Just tried to make SOY milk cappuccino this morning. Yuck. But maybe I will get used to it. It tasted like my cappuccino was made of cardboard. :-pjherm77 wrote:This is of course without having a full assessment of your eating/fitness/tobacco usage habits. Maybe you can use a lower fat milk in your caps?
No, that is the concerning issue, which is why I brought it here. I always ran around 180-190 before I got my La Spaziale and started drinking espresso and cappuccino at home on a regular basis. Now, it has jumped up by 40+ points. Could it be a coincidence?John B. wrote:Is this the first time you've had your levels tested?
Adrian
- JohnB.
You might want to get it rechecked in a couple months as my doctor tells me levels can change regularly depending on what your body is up to. Was the increase all LDL?drdna wrote:No, that is the concerning issue, which is why I brought it here. I always ran around 180-190 before I got my La Spaziale and started drinking espresso and cappuccino at home on a regular basis. Now, it has jumped up by 40+ points. Could it be a coincidence?
LMWDP 267
- RapidCoffee
Alan Adler (inventor of the Aeropress) has been harping on this topic on CG for some time now. Paper apparently filters out the cafestol and other potentially harmful diterpenes. For that reason (and taste tests), he refuses to market metal filters for his ingenious device.drdna wrote:The concentrated aromatic oil fraction in French Press coffee and the corresponding crema in espresso may contribute to elevations in "bad" LDL cholesterol and depressed "good" HDL cholesterol, as described in various studies.
Like most dietary research, these conclusions are open to dispute. But I do believe this is of concern to espresso drinkers, and we should monitor new studies closely. Whether you believe there is sufficient evidence to give up unfiltered coffee is of course up to you.
My cholesterol increased significantly since I started drinking espresso regularly a few years ago. But there are a number of other factors that might have caused this, notably age and genetic programming (both my parents had high cholesterol). Diet and exercise had little impact, so I went on statins last year, and the lipid counts dropped back down.
Nutritionist or not, this comment misses the point. There is no cholesterol in coffee per se, but there are diterpenes (such as cafestrol) which may elevate cholesterol levels, presumably by increasing the amount of cholesterol produced by the body.jherm77 wrote:I happen to be a nutritionist/educator and cholesterol is one of my specialties. Your main concern in raised LDL levels and triglycerides is saturated fats, more specifically long chain fatty acids (LCFA). You won't get this from coffee oils, as most LCFA come from animal and man made fats.
John
I will just add that anyone concerned about cholesterol and considering statins might consider doing a little research, as the problems with cholesterol and the effects of statins is not a simple topic with clear conclusions (not that I will dispute that high cholesterol is not a serious symptom or that statins might be the solution).
Christian B.
