Custom Cut Coffee Filters
- ash4889
I've been cutting my filters by hand to fit my portafilter, its getting old real fast doe's anyone know where can I turn to get 2inch custom cut filters?
There are tools to make it easier to cut things like that:
https://www.amazon.com/Mayhew-50525-2-I ... B008M23VUY
is one example.
Ira
is one example.
Ira
- ash4889 (original poster)
Hey thank you so much Ira that's a definite starting point, Everything was OK until I looked at the price.ira wrote:There are tools to make it easier to cut
is one example.
Ira
Lol lol lol
I got a good staring point from you, take a look at what I found online??
- MB
So, I have an EK 1.5" circular punch and tried it out on V60 filters. First I tried one layer and, as I suspected, it tore partially instead of cutting neatly. Then I got similar results with two layers. Then when I tried 4 layers (two stacked full filters), I got a neat sharp cut.
LMWDP #472
For the filters at the bottom you can get Whatman 597 filters in 55mm for a great fit. I'm not sure about the top, yet.
It would be good if I have a big portafilter, but mine is 54mm on the top and 2inches on the bottomCwD wrote:For the filters at the bottom you can gWhatman 597 filters in 55mm
It looks like Whatman Grade 4 filters are available in 50mm, which should fit perfectly!
Here's a link: https://www.amazon.com/dp/B00394F9OQ/
Wow Mitch thank you so much for that info, I'm going to order some today.
