Cheap homemade WDT tool - Page 2
- GregoryJ
That's just a rubber plug I had lying around. Rubber was nice because I could poke holes into it with a pencil, but if I make another one it will be with a wooden handle I thinkmichael wrote:I like it, a cut above my 2 double pronged ss corn holders wired together
Do you have a link for the handle
I'm nominating this as an early frontrunner for best thread of 2019. Please keep the examples coming HB!
- randomorbit
- MB
:O I need this! How can I obtain this exact tool? haha... it's essentially the Londinium tool, which I refuse to pay $50 + $40 shipping for.leozava wrote:Very similar to what came with my helor stance motor
<image>
Very nice tools above. Let me introduce mine, simple cake tester :
It was cheap which was needed only $1 at nearby grocery store. Easy to clean after job done.
I tried this tool, mini cocktail whisker, as an original shape and modified later :
I tried the whisker with original three rings at the first time. It broke clumps fast but It was not easy to clean as simple cake tester. Then I modded it by cutting rings one by one. I ended up having only one ring which looked cool and was fairly fast to break clumps and redistribution job. It ,however, made me be more careful while stirring coffee ground than when with simple tester since I like vigorously stirring my coffee ground in my basket and homemade funnel. And slightly harder to clean. I just sweep the tester with my thumb and forefinger to clean. That is just simple and satisfying.
- LBIespresso
- Supporter ❤
I use the same. They vary in thickness though. I did find a super thin one that I like better than a thicker one I started with. I also used a whet stone to round out the tip so it would be easier on the basket. I am curious about the Londinium tool people here seem to rave about but not > $50 shipped curious.mammamia wrote:Very nice tools above. Let me introduce mine, simple cake tester :
LMWDP #580
- Moka 1 Cup
Any luck?randomorbit wrote:I was looking for the poker from a dissection kit, but the kit I found had a slightly different poker which I think looks better than the common ones I've seen. I'll let you all know how it works out.
<image>
Mmm nice, a little on the short side, but very nice. Things to think about, haha.Moka 1 Cup wrote:A spare brass pin punch....
<image>
