Bob 16g basket
Want to talk espresso but not sure which forum? If so, this is the right one.
salmotrutta
#1: Post by salmotrutta »
I've been a long time user of the espressoparts HQ 18g basket, but as many have noted it holds a lot more than 18g and I began to tire of the sloppy pucks.
I wanted a 16g basket so I could pull 1:2 shots in the 30g ballpark, or run a little longer for light roasts. I'm cheap so took a flyer on the BIT "bob" basket for only $15, which is distinguished by its convex shape and lack of holes on the sides. It's supposed to produce sweeter shots and allow coarser grinding.
After a few months of use, jury is still out on whether the shots are sweeter but I do like the basket. Rather than allowing a coarser grind, I find it flows faster. Most of all, I like the capacity and the price point.
Splatcat
#2: Post by Splatcat »
I got the Bob 21 gram and dose 18. I love this basket.
salmotrutta (original poster)
#3: Post by salmotrutta (original poster) »
You find it runs fast?
Splatcat
#4: Post by Splatcat »
No. But I am getting much better tasting shots with loads more mouth feel and body. I switched from a 21g VST and the difference was noticeable immediately.
coyote-1
#5: Post by coyote-1 »
Sooo... if one were to take an existing basket, and gently tap it into a slightly convex bottom and then add a thin steel ring that blocks the outer holes, one could approximate this. Right?
#6: Post by salmotrutta (original poster) »
I don't know what you're up to but just buy it, it's 15 bucks
