Beanconqueror - App - Page 10
Want to talk espresso but not sure which forum? If so, this is the right one.
Jeffmurray
#91: Post by Jeffmurray »
Jeffmurray wrote:Thanks Lars, much appreciated.
For the blend, I currently just archive the beans and add a new one. I agree it would be hard to add something to record this.
Thanks for the tip I will turn on the parameter.
Actually, I now have created some additional brew methods : i: gift, ii. waste and iii. blend. This way the roasted beans archive when I blend them. It works well for me :-)
Jeffmurray
#92: Post by Jeffmurray »
I have come up with a way to deal with blends. I added a Method called blend. When I actually blend the roasted beans, I create two brews via the blend Method for the full weight of the beans and they automatically archive. I then create a new bean with the total weight of the archived beans.
I've also created two other methods called Waste and Gift for other purposes.
All works well for me. :)
Graphefruit (original poster)
#93: Post by Graphefruit (original poster) replying to Jeffmurray »
Great to hear this! And even better it works for your use cases :)
Jeffmurray
#94: Post by Jeffmurray »
What visualizer (Android) do people use with the export function?
#95: Post by Graphefruit (original poster) replying to Jeffmurray »
How do you mean this?
The export is for this platform: https://visualizer.coffee/
#Spoiler - In the next version, there will be the possibility to upload automatic without doing it by hand.
Best
Lars
#96: Post by Graphefruit (original poster) »
Hello Coffee-Lovers,
the new Version 7.0 is live today!
What have been changed?
Bluetooth Scale Mode
Start the timer on the first detected change in weight - Activatable in the settings (new button visible)
Ignore the current transmitted weight - e.g., for swirls, stirs, or removing weight without intentional graph spikes - Activateable in the settings (new button visible)
Bluetooth Scales
Support for a Bluetooth-No-Name scale
When connecting a DiFluid Microbalance or Felicita scale, the command delay is set directly
Graph Area
Activate the graph area in the settings
Set a brew graph for a new brew to follow it
Graphs can come from a brew or from the individual graph area
Upload your own graph - Export a .JSON file from your brews
Visualizer
Automatically upload each new brew with a connected graph to Visualizer - Activatable in the settings
Manually upload all brews to Visualizer if needed
Thanks to Miha for the support!
Brews
Repeat a brew from the detail view
First-drop can now be activated for a preparation method, even if it is not an espresso method (e.g., Pulsar)
Display of brew rate with a connected scale in the maximized view
Last brews are now sorted alphabetically, and the last used date is displayed
Real-time flow with a connected scale now shows values under 1g/s for espresso
Beans
Repeat the last brew or the best brew from the beans view card
Preparation method
Preparation tools are now sorted alphabetically and can be filtered
Last usage of the preparation methodology is now displayed when selected
Grinders
Last grind size and last usage are now visible when selecting a grinder
Xenia
Bug fix: Deactivated scripts are no longer executed
Settings
Display of a security prompt if you have made changes to a brew or a bean - Activatable in the settings
Now set your individual start X- and Y-Axis for brews with bluetooth devices
Ionic 7
Update from Ionic 6 to Ionic 7
Minimum version for iOS is now iOS 14
Minimum version for Android is now Android 7.1
Lokalise
Use of Lokalise for all translations - Many thanks to Yannick
Want to translate too? With Localise, it's now easy. Contact us: info@beanconqueror.com
Other
Minor bug fixes
You can find the app here:
Android: https://play.google.com/store/apps/deta ... queror.app
iOS: ‎https://apps.apple.com/en/app/beanconqu ... 1445297158
Github: https://github.com/graphefruit/Beanconq ... tag/v7.0.0
Best regards
Lars
bznelson91
#97: Post by bznelson91 »
New user, loving the app on my iPhone, but am having MacOS problems. When I load the app on my MacBook Air (7.0.1), and select Beanconqueror -> Settings, I get this screen:
This is where I'd expect to see the Import and Export options, among other things.
Any ideas?
Brad
bznelson91
#98: Post by bznelson91 »
OK, I'm still learning. :) I figured out that all of the menus are just OS supplied defaults. The nav is in the app itself, so I did the sortof-hamburger at the top left, and then Menu -> Settings -> Import.
So, next problem: I exported the data from my phone, then sent the zip to my MBA. I then tried the import with the zip, and then with the JSON file within the zip. Both failed silently, there's no data imported. I also tried exporting to XLSX and importing, same thing, silently failed.
Did I do something wrong?
Brad
#99: Post by Graphefruit (original poster) »
Hey Brad,
sorry - MacOS is not supported, just iPhone and iPad.
Also to mentioned: Just .ZIP files can be imported with the latest Version.
There is a backup mode to .JSON but this is not recommended anymore.
XLSX files cant be imported.
Hope that helps, else please ask again.
Have a great cup of coffee
Lars
SteveOhh
#100: Post by SteveOhh »
Lars, thanks for the app and all the work to support it. I'm trying to get brew charts to work with my new Acaia Pearl, specifically the scale's auto-start mode (the timer starts when you start pouring). I want to use the scale's auto-start and not the app's because the scale mode also does some arithmetic for me and calculates the net brew weight. I haven't been able to find any guide for how to use the app in depth, and Google keeps directing me back to this thread. Is it possible to use brew charts in this scale mode?
