Beanconqueror - App - Page 6
Hi Nutra,The Nutra wrote:Hi Lars, can you help please?
I successfully upgraded to 6.1 on Android and used for a day or 2. Then somehow at app start I got a full white screen. I tried uninstall, reinstall. Loos the same. Can I either get a full clean status somehow or put my latest .json file to the right place to get back to normal? (I have USB access to the phone files and I have the exports.) Thanks. As workaround I moved to my iPhone instead but the screen to small there for my old eyes...
I'm very sorry to hear this
Please open a file tool and goto "Download" folder, and create here a new folder with the name "Beanconqueror_export", in this folder, please put your JSON file and your images.
After this you can go into the app -> settings -> import and choose the latest JSON file.
If you don't have your images exported and also put into the "Beanconqueror_export" folder, we have sadly no chance anymore because you've already uninstalled the application. There was a workaround I posted, but this just worked if the app was still installed.
Let me know if I can help you further.
You can also reach me via email: info@beanconqueror.com
Have a great day
Lars
Hi Lars,
I have something different problem. I have the export folder, the files are there as per your faq. The initial import after the upgrade was all OK, every data appeared in the app. But now when starting the app, I literary got a white screen, no menu, nothing.
This remained even after uninstall, moving all files to a safe place, deleting any BC related folders (at least the ones I know) and then reinstall. I hope this better describes.
However, this seems to be a unique issue, so I better contact you in mail, not to OFF the topic.
BTW, with all the exported data, I still can nicely use the new version on my iPhone, so nothing lost.
I just simply prefer my bigger Samsung Note screen and would like to get a real clean install showing the menu, so I can import all my current data.
Hey Nutra,
at first: Happy that you don't have data loss!
Please send me an e-mail: info@beanconqueror.com.
With this e-mail please attach me the .JSON-File which you are importing into your Samsung Note so I can have a look at it.
Thanks in advance
Lars
Thanks in advance
Lars
Hello Coffee-Lovers,
the new Version 6.1.5 is live today!
A small patch
What have been changed?
QR Codes
Reload beans which where scanned via qr-codes
Brew graph
Water flow is calculated now in realtime - Specially for espresso
Beans
Search beans now in selection
Bug fixes:
After taking a picture, the loading spinner didn't disappear
Smaller bugfixes
You'll find the app here:
Android: https://play.google.com/store/apps/deta ... queror.app
iOS: https://apps.apple.com/us/app/beanconqu ... 1445297158
Github: https://github.com/graphefruit/Beanconq ... ag/v.6.1.5
Best regards
Lars
A small patch
QR Codes
Brew graph
Beans
Bug fixes:
Smaller bugfixes
Best regards
Lars
the new Version 6.2 is live today!
Pressure devices
Support of 'Do it yourself' Popsicle - Sensor - Thanks to Mike and Shay
Autostart timer on a specific pressure - editable in settings
Press of pressure gauge, will reset pressure to 0
Display name of pressure device and mac-address on connect
Bluetooth scales
Support of Eureka Precisa - Thanks to Mimoja
Define the behavior of the bluetooth scale on a new brew - editable in settings
Define which graphs should be displayed on filter or espresso - editable in settings
Sequential processing of bluetooth commands to reduce issues
Display name of bluetooth scale and mac-address on connect
Brews
Supports now milliseconds - Activate in settings
Filtersystem expanded, search for roast type and roastery
You can reconnect your bluetooth scale or pressure device on the brew add/edit page
Beans
Share your bean (without server needed) - Thanks to Mike
Show all brews to your bean
Support bean rating like for brews - editable in settings
More languages
Support of Turkish - Thanks to Halil Portakal
Support of Chinese - Thanks to Jiageng
Mills
Display of the last used grind setting, aswell as the last used bean
Improvements
Error message when a bean is scanned, which has not been approved yet
The edit of the brew-date is not activated by default
Others
Typos fixed
Fixed an issue that you didn't see the star-rating even with normal settings
Older brew graphics can now be exported again
Update to Ionic 6.3.0
Smaller bug fixes
Scale"hack":
Some has encountered the issue, that the scale is sometimes not proper connected, even so it shows its connected, but the weight is not transferred.
You can now reconnect the scale inside a new brew or when editing a brew.
If the weight-tile is not showing "?" anymore, the connection should be stable and the weight is transferred.
Github: https://github.com/graphefruit/Beanconq ... ag/v.6.2.0
Any feedback is appreciated!
Enjoy the last October days!
Lars
Pressure devices
Bluetooth scales
Brews
Beans
More languages
Mills
Improvements
Others
Typos fixed
Smaller bug fixes
Scale"hack":
Lars
The app would deserve a bit more traffic here... I'm at 585 brews and love it.
Question: recently I bought an Acaia Lunar. What is the right mode to use for espresso brewing?
For bean I use the simple weight mode, but lost which is the good one for the actual brewing? I have a fix preinfusion and so far I measured from pump start, also adding the first drip and stopping at target weight.
I did not find any help for this. Is there any somewhere?
Thanks.
Thanks.
the new Version 6.3 is live today!
Bluetooth scales
Define who long shall be waited until the next bluetooth command
Brews
Reset the Brewtime dates
If Bluetooth-Scale connected, the last brew weight will be displayed in the tile
Bigger buttons on the maximized brew graph
Choose excel or json by downloading the brew data
Bean pictures can now be displayed, instead of preparation method icons/pictures -> Activate in the settings
Beans
Beans can now be searched by there varieties
Mills
Displaying notes inside the list and detail view
Improvements
Choose how many milliseconds shall be displayed (Entered values still need to be 3 decimal places)
Added donation buttons (just Android)
Textareas are now scrollable
Brewtime at statistics are now formatted
Notification popups appear now on top and can be closed by X
Disabled detail parameter are active now, e.g. can now be the Grinder be hidden
Analytics can be deactivated or activated
Others
Typos fixed
Update to Ionic 6.4.0
Smaller bug fixes
Github: https://github.com/graphefruit/Beanconq ... tag/v6.3.0
Enjoy the last and hopefully chill days in 2022!
Lars
Bluetooth scales
Brews
Beans
Mills
Improvements
Others
Typos fixed
Smaller bug fixes
Lars
Hey The Nutra,The Nutra wrote:The app would deserve a bit more traffic here... I'm at 585 brews and love it.
Thanks.
thanks for the feedback!
Actually just the normal weight + timer mode is good working on Beanconqueror, other modes like, detect first drip etc, is not working on Beanconqueror.
Hope that helps!
Best regards
Lars
I just discovered the app over the Christmas holidays... and I'm extremely impressed.
Before, I was tracking espresso brews in a notebook. Works fine, but was unstructured and became a bit unorganized over time. Switched to the app now and it works really great: I record the brews and use it to look up my grinder adjustment for specific beans (single dosing). Dose and yield are read directly from my Lunar. The app seems to have a lot of options to configure. One potential additional feature that might be interesting (not 100% sure myself): I have to select the beans for every brew out of my list of beans. If I could add an RFID tag to the bag, putting the bag close to my phone would allow to automatically detect the beans. Downside: you have to attach and configure the tags.
Overall, a pleasure to use so far. Thanks to the developers!
Best wishes,
Bastian
Best wishes,
Bastian
Been using this for a year now. Such a great app.
My one quality of life suggestion would be to add a 'repeat last' button to the brews tab. Perhaps beside the 'add brew' plus button or as an optional replacement. Right now you need to tap on the three dots beside the last brew, then tap repeat.
It's a minor issue for sure, but I think a lot of people probably want to repeat the last brew to bring the settings over, then tweak as needed
