Beanconqueror - App - Page 5
Lars,
I've been meaning to thank you for the Bean Conquerer app. I use it constantly on my iPad Pro to track the various coffees I've tried making espresso. Serves my needs quite well. I have one suggestion/question-
When scrolling through the lists of saved BREWS is there a way to show the roaster's name alongside the coffee name without having to drill down into the brew data? I have enough brews logged for quite a few coffees that I forget which roaster produced which beans - or maybe I'm just getting terribly old and can't remember much these days
Dave
Dave
GreatThe Nutra wrote:With some delay
Yes, this is how it works. Cool.
Hello Dave,daveR1 wrote:Lars,
Dave
what a lovely feedback! Thank you so much .
Good idea! I've added it.
If a roaster name is added, it will be added after the bean name.
If no roaster name is added, it will be like before
Here a small screenshot:
If you got more questions or ideas, just let me know
Have a great day!
Lars
looks exactly like i was thinking of. will that feature be added in the next update thru the Apple app store?
Hello Dave,
this feature will be inherited in the next update (Version 6.1), this one will be rolled out via Apple Store.
Actually I'm waiting for the Spanish translation, after that I gonna update the version.
Have a great day
Lars
Have a great day
Lars
Hi Lars,
I usually use the repeat functionality for my brews, saving a lot on entry. However, I don't know how not to copy over the rating. Is there a good trick? Thanks.
Hello Coffee-Lovers,
the new Version 6.1 is live today!
Before you start reading the patch notes:
Sadly there was an issue on Android with the Play Store.
If you didn't already read the popup screen, please make sure to go to the faq page: https://beanconqueror.com/faq
What have been changed?
QR Codes
Scan your coffee bags! All coffee information are directly inserted from the roastery.
Bluetooth scales
Support of Acaia Pearl 2021 - Thanks to Micah and Mike
Support of Acaia Lunar 2021 - Thanks to Micah and Mike
Support of Acaia Pyxis - Thanks to Micah and Mike
Support of Hiroia Jimmy - Thanks to Silas
Support of Felicita Arc - Thanks to Herman
Care: Acaia Pearl lower 2021 is not supported right now
Weightinformation of bluetooth scale can now be used on the beans page
Weight changes are now visible without starting a brew via timer
Brew overview
Customize your visible brew parameters in the overview in general or for each preparation method
Preparation images are now visible in the listview
Brew graph
Rework of brew graph to a more smoother solution
Brew graph now can be maximized
Brew graph can now be zoomed in the brew-detail view aswell as exported
Average flow quantity is now displayed
Beans
Added fields: Buy date, FOB-Price, Purchasing price
Beans can now be favorited and filtered
If a bean gets archived, you can now rate the package aswell
Pressing '+' you can now choose to add or scan a new package
Long press '+' to directly add a new bean
Preparation methods
Preparation methods can now be repeated with all settings
More preparation methods are available - Thanks to Nicola
Selecting a preparation method also displays the image
Settings
Ratings can now be stepped (1, 0.75, 0.5, 0.25, 0.1)
Bluetooth scale - Define if the scale should be set to weight zero when starting a new brew, or starting the timer
Bluetooth scale - Define if you want to ignore anomalies or negative values - if yes, a live graph won't be possible
Choose now, if you want to see archived brews on the home page
Export also now exports the raw data of the saved bluetooth values
Improvements
Delete of preparation method tools now won't delete brews anymore
Preparation method tools now can be edited and archived
Bug fixes:
Recording or choosing images on Android works now on newer versions
Found more issues which could lead to a data loss
Small bug fixes
Others:
Updating to Ionic-Framework 6, therefore some small visual changes takes place
You'll find the app here:
Android: https://play.google.com/store/apps/deta ... queror.app
iOS: https://apps.apple.com/de/app/beanconqu ... 1445297158
Github: https://github.com/graphefruit/Beanconq ... ag/v.6.1.0
Best regards
Lars
QR Codes
Bluetooth scales
Brew overview
Brew graph
Beans
Preparation methods
Settings
Improvements
Bug fixes:
Small bug fixes
Others:
Best regards
Lars
Hello together,
for all people suffering on data loss, and didn't had any automatic backup.
I could retrieve a way which is a bit "hacky" and you need some sort of technical knowledge, but its possible to over install an older version from Github where the app can access the old database.
Important thing: You never delete the Beanconqueror app!
More information can be found here:
https://github.com/graphefruit/Beanconq ... 1112638471
Let me know if I can help further
Lars
Lars
Hi Lars, can you help please?
I successfully upgraded to 6.1 on Android and used for a day or 2. Then somehow at app start I got a full white screen. I tried uninstall, reinstall. Loos the same. Can I either get a full clean status somehow or put my latest .json file to the right place to get back to normal? (I have USB access to the phone files and I have the exports.) Thanks. As workaround I moved to my iPhone instead but the screen to small there for my old eyes...
