Beanconqueror - App - Page 3
Version 5.0
After many month of development time, there goes a new version
What has been changed?
iOS:
https://apps.apple.com/app/beanconqueror/id1445297158
Android:
https://play.google.com/store/apps/deta ... queror.app
Github:
https://github.com/graphefruit/Beanconq ... ses/tag/v5
I wish you all the best, some restful days and a happy new year in advance
Lars
- New layout, new icons, new colors, new logo
- New preparation methods
- Preparations now can be categorized (percolation, espresso, full immersion)
- Preparation can now inherit tools (e.g. different filters)
- Preparation parameter can now be customized, define your own workflow for each preparation
- Added more editable bean information, different sorts can now be added
- Amount of water field is available for percolation/full immersion
- Where did you brew your best coffee? Active coordinate saving in settings
- Activate fast repeat to add brews instant
- Added update screen to show the latest changes
- Question added to rate the app after 25 uses
- Added sorting for beans
- Added search panel for brews/beans
- Cupping chart is added to brew details
- Left over beans weight added on homescreen
- Added typeahead for roasters
- Rating moved to stars instead of icons
iOS:
Android:
Github:
Lars
Sorry for the long delay!Rainer wrote:Hallo Grapefruit
First of all thank you for your wonderful app. Unfortunately, the app hangs up in the brewing-screen. So I can fill in all parameters and also save them, but the screen doesn't close, so I'm trapped.
Do you see any solution?
I'm using iOS 14.
Regards from Germany
Rainer
Can you reproduce this issue with the latest update?
Greetings
Lars
Version 5.1 is live!
Changes:
New timepicker for brews
Roasting date can now be again selected on iOS
Images can be choosen again on iPad
TDS calculation is now again visible on beverage quantity
Safe zones added for iOS-devices
iOS:
Android:
Github:
https://github.com/graphefruit/Beanconq ... ag/v.5.1.0
Greetings!
Changes:
iOS:
Android:
Github:
Greetings!
Nice job!
But it would be great if you add sections for input the recipe for each methods.
And add option to paper filters.
One extra feature I would find very helpful to add is a record of the grinder setting used for each bean. I currently write this down so I know what to use if I get the same bean/blend again.
Hi there,EndlessOcean wrote:Nice job!
Sorry for the late response, I didn't receive an email.
Thanks for your request.
Recipe is actual one thing on a list which was often asked for but Beanconqueror is in the first place not a recipe App like other apps on the market.
I know there is a need and I'll look for a option/solution, but not in a close range.
Paper filters:
I don't know what exactly you want to request here, in the latest update of Beanconqueror, you have the possibility to add "preparation tools" inside the preparation.
This is thought for different baskets on the portafilter like VST, 18g etc, or like on a V60: netherlands filter, japan filter, cloth filter, metal filters or something like this.
Can you have a look if this would fit your needs, else I'd like to ask you to give me some more details on this request
Best regards
Lars
You can activate different parameters inside the app, also the grind setting.HH wrote:One extra feature I would find very helpful to add is a record of the grinder setting used for each bean. I currently write this down so I know what to use if I get the same bean/blend again.
If you have multiple brews, you can filter by beans, and look up which grinder settings you've set.
Does this help you?
Greetings
Lars
Dear Coffee-Lovers!
Beanconqueror 5.2 is live!
Whats new:
Brews:
Brew timer continues in the background
Brews can be favored
Screen for adding and editing a brew looks identical
Display can stay active during brewing (can be activated in the settings menu)
List of recent brews now also shows archived brews
Beans:
Bean photos are shown in the overview
Beans can be rated
Interactions:
Long press on a card leads to the edit view
Detail view can be accessed via click on the card
Github / Facebook / Instagram accounts linked
Bugfixes:
Bean information have been copied incorrect
Brew amount was activated by default for new users
Other:
Apple Healthkit integration (can be activated in the settings menu)
Cleanups
Layout changes
Extension of statistics
Startup check revised
Support for different card sized for brews and beans
And may more small changes!
Android: https://play.google.com/store/apps/deta ... queror.app
iOS: https://apps.apple.com/de/app/beanconqu ... 1445297158
Oder directly on Github: https://github.com/graphefruit/Beanconq ... tag/v5.2.0
Greetings
Lars
Whats new:
Brews:
Beans:
Beans can be rated
Interactions:
Bugfixes:
Other:
Cleanups
Layout changes
Greetings
Lars
Dear Coffee-Lovers!
Beanconqueror 5.3 is live!
Whats new:
Brew methods:
Custom images can be attached in the edit screen
Brew tools will be saved in edit screen, even when '+' is not pressed
Grinders:
Brews:
Parameter 'Attachments' renamed in 'Attachments / Photos'
Dashboard:
If bean amount is less then 1000g, the number will be written as a whole
Bug fixes:
Editing via a long-press, does not change information any more
Information on the dashboard are updated after made changes
Directly on Github: https://github.com/graphefruit/Beanconq ... tag/v5.3.0
I'd love to hear your feedback!
Lars
Whats new:
Brew methods:
Grinders:
Brews:
Dashboard:
Bug fixes:
Lars
We did it!
The last weeks and months we worked hard to create a website for Beanconqueror and for YOU.
The summer is slowly kicking in and we want to support YOU to find the right information about Beanconqueror and share the love with your friends.
Questions about our vision, roadmap, running costs or even the changelog for each version, everything already up on the website.
Check it out, give us feedback and enjoy every coffee!
-> http://beanconqueror.com/
Lars
Lars
