I've just found a sad bug, please do not activate "Starting Page: Add Brew"
Its fixed it in the next update.
Beanconqueror - App - Page 2
Next version is in development.
Which changes will be included?
Fixing one bug that overlay could not be closed.
Added preparation type (Pour over / espresso) with this dynamic fields for brews are introduced.
Fields like water quantity is not needed for espresso and not visible then.
Added a small typeahead feature (more when finally implemented).
Added a rating popup after 25 uses (so enough to get the app known
Added an update popup to tell the user which has been changed.
Added the possibility to track your brew location (Need to be enabled in settings)
More incoming, just a small headsup
Like the app a lot and use it daily, thank you!
Can we add the cupping option to the Bean section?
Howard
Howard
Hey Howard,
thanks for your feedback.
Could you give me a bit more detailed briefing?
Actual there is a cupping function on the brew itself.
The idea is to add a new preparation method: "Cupping"
With this you could brew your beans and cup them with this specific method.
Is this a solution or you mean something completly else?
Right, actually I mean the cupping / scoring function which can be chosen inside the brew section but not the bean section. (As I do home roasting and cup the roasts so I thought as I add a new roast it would be nice to score it at the same time). Though yes I suppose I can create a cupping in the brew section then add the cupping score. Thank you!
I don't want to force you to use another style of cupping.
I just want to get the use case to know.
I'm not that much into cupping, therefore I thought that cupping of beans is done several times.
If there is a real feature to cup the beans directly on the beans itself, without having a "brew" between it would be fine for me.
Just need to understand why so the integration with UI/UX can be added.
Whats coming up next?
At the moment the next version is in development, which will take a bit.
For some anticipation, what will be in the next version?
- New styles/layouts for brews/beans/preparation methods and grinders
- Beans can inherit now much more information like blended-sorts
- New prepration methods
- Prepration methods can now be categorised (full immersion brew, pour over, espresso)
- Preparation methods will have customizeable brew-parameters, so each preparation method will show you YOUR selected fields to be filled.
- And maybe some little tweaks aswell
If you have more feature requests feel free to contact me.
Greetings!
Greetings!
Hallo Grapefruit
First of all thank you for your wonderful app. Unfortunately, the app hangs up in the brewing-screen. So I can fill in all parameters and also save them, but the screen doesn't close, so I'm trapped.
Do you see any solution?
I'm using iOS 14.
Regards from Germany
Rainer
I'm using iOS 14.
Rainer
Hallo Lars,
habe gerade entdeckt, dass du auch aus good old Germany kommst. Ich hätte mir also meine Übersetzung sparen können.
Ich registriere mich mal noch im Kaffee-Netz...
Herzlichen Gruß
Rainer
Herzlichen Gruß
Rainer
