Acaia Lunar flow mode
- nixter
Recently purchased a Lunar (non 2021) and I'm finding the flow mode to be quite useless and flaky. It doesn't start the timer on first drip, it waits until it senses a continuous flow. I even confirmed that this behavior is intentional with Acaia. Does anyone else find this strange? I'd like my shot timer to start upon first drip, or at least have the option. To make matters worse, it doesn't even always detect flow properly and won't start until mid shot. Not what I'd expect for this much money.
Have you updated the firmware? Pretty old at this point but maybe yours had an older version installed.
https://acaia.co/blogs/news/new-lunar-firmware-2-6-003
On mine, the timer and flow detection is fairly spot-on and immediate.
It's a little off at times that's for sure. It's supposed to be geared for espresso use and so the flow sensitivity is somehow dialed into that. Espresso machines can have a lot of vibrations and I think it's design to interpret what a weight fluxuation is and what a vibration fluxuation. It may do a better job at this if you eliminate vibrations like if it's own stand that doesn't touch the machine. It doesn't bother me because my machine has its own flow control/shot timer. The main thing for me is the weight.nixter wrote:Recently purchased a Lunar (non 2021) and I'm finding the flow mode to be quite useless and flaky. It doesn't start the timer on first drip, it waits until it senses a continuous flow. I even confirmed that this behavior is intentional with Acaia. Does anyone else find this strange? I'd like my shot timer to start upon first drip, or at least have the option. To make matters worse, it doesn't even always detect flow properly and won't start until mid shot. Not what I'd expect for this much money.
Does anyone know if the flow mode is simply a firmware upgrade that you can add to a pre 2020/21 model? Or is there new hardware as well?
Not sure what you mean... the original has the flow mode feature.
https://acaia.co/collections/coffee-sca ... 2024857778
Unless perhaps you're referring to the flow rate indicator in the 2021 model?
- nixter (original poster)
My Bianca has a shot timer as well but it starts from "lever up". I assumed "flow mode" would start at first drip but I guess it starts when it senses continuous flow, as the name suggests.DamianWarS wrote:It's a little off at times that's for sure. It's supposed to be geared for espresso use and so the flow sensitivity is somehow dialed into that. Espresso machines can have a lot of vibrations and I think it's design to interpret what a weight fluxuation is and what a vibration fluxuation. It may do a better job at this if you eliminate vibrations like if it's own stand that doesn't touch the machine. It doesn't bother me because my machine has its own flow control/shot timer. The main thing for me is the weight.
- CarefreeBuzzBuzz
Have you adjusted the Auto Start Sensitivity
Auto-Start Sensitivity [ SEnSE ]
1. Minimum weight is decreased for more sensitivity. This is ideal for slower espresso shots in the
modes. Stability depends on environmental noise. The previous firmware started the timer at ~0.6 g into an espresso shot.
2. The number indicates the sensitivity of flow detection in the modes. Smaller value indicates higher sensitivity, but is recommended only for stable working environments.
0.1 g, 0.2 g, Off
Within the setting choices in the manual, you might discover other options you like as well. For example, have you turned off the modes you don't use?
0.1 g, 0.2 g, Off
- CarefreeBuzzBuzz
One other thing if you are new to Lunar.
Do NOT steam with the Lunar on the drip tray. They aren't waterproof from the underside.
Do NOT charge with some high powered charger. Use a small 2.1amp (smallest Apple or Android) charger.
Your battery will thank you in a few years.
CarefreeBuzzBuzz wrote:Have you adjusted the Auto Start Sensitivity
0.1 g, 0.2 g, Off
Thank you, sounds like this might be the issue/solution
