TC4 Shields Available - Page 3
Question: why is the zero cross detect needed as a separate piece of circuitry? Aren't most all solid state relays equipped with zero cross optocouplers internally?
Mark S.
Mark S.
- greencardigan (original poster)
The zero cross detector is used for doing phase angle control modes with a random fire (instantaneous fire) SSR.
The Arduino needs to know when the zero cross event occurs so it can then switch power on at a certain number of milliseconds later depending on the required power output power.
As long as you have speed control of your motor. A ZCD and SSR can be added later. It may just require changing the mode used in the TC4 sketch depending on what you already have on it.
I should be building more ZCD's on the weekend hopefully.
You can potential use the LCD as is by connecting all the required pins to the arduino but I have not actually confirmed if that still works with the TC4 sketches. I'd recommend getting an LCD with an I2C interface. It will make the connection much simpler.
