Sous-Vide Coffee Roasting
- hankua
This Topic has come up before, apparently a Taiwanese roaster from Kaohsiung sent an Ethiopian roast to Coffee Review recently that was prepped pre-roast using sous-vide. ( @60*C for 3 hours) Translation help gratefully accepted
https://www.facebook.com/groups/4395368 ... 4427752386
I'll try that 'esoteric' approach one day soon, as I also wondered a couple of times what it would do if anything...have to thaw the greens anyway.
LMWDP #483
Aw heck, I thought you were going to say I could use the sous vide to do the actual roasting.
Now that would be very cool....I mean hot.
- another_jim
Same here.
Given that the internal pressure of the bean during roasting goes up to about 30 bar, and that the first crack is the bean's moisture coming to a boil, my skeptical side tells me this is some magical/marketing hand waving, with no discernible physical effects, that accompanies an otherwise good roast of a good coffee.
In any case, it's a new entry into my coffee stories catalog: woke origin stories, ancient craftsmen stories, mr. science extraction stories, and now molecular cuisine roasting stories.
Jim Schulman
Might be a good way to ensure a consistent greens temperature without having to invest in a room that's always the exact same temperature year round.
I believe it's more about causing a forced germination for a more flavorful roasted coffee.
- another_jim
Forced germination? Coffees are patio or kiln dried for days to weeks, and never does a single bean sprout.
Jim Schulman
Yea, activating the embryos metabolism. Or it could be used to jump starting the yeasts/microflora. That's my guess.
that is my guess too, no voodoo in sous vide just a very even temp distribution within the greens.CwD wrote:Might be a good way to ensure a consistent greens temperature without having to invest in a room that's always the exact same temperature year round.
I find that green temp has quite an effect on how easy a roast is to control..no scientific data, just a hunch that having a homogenous temp within the bean will help and elevating the start temp at charge likely does not hurt at all. I now nuke the frozen greens but the resulting bean temp across beans is so uneven that temp within a bean also will be very different.
LMWDP #483
If I remember correctly, I tried this a few years ago with beans vacuum bagged single layer deep so there is enough contact instead of bunched up and that sous vide'd. Surprisingly not much moisture in the bag after done.hankua wrote:This Topic has come up before, apparently a Taiwanese roaster from Kaohsiung sent an Ethiopian roast to Coffee Review recently that was prepped pre-roast using sous-vide. ( @60*C for 3 hours) Translation help gratefully accepted
I don't think I find it different from just roasting the beans sans sous vide.
But maybe someone out there can demonstrate with their recipe (time and temperature) that the roasted coffee compared to the regular roasted ones are superior.
