Small roaster for Nano Roastery - Page 3
Hello
I'm disappointed ... I'm such a stupid guy to have a brainless ...
I am very interested in the huky et cie ... but ... after 2 min of reflection .... I think of gas ..
In Quebec, using a propane stove is not allowed with us ...
the risks with CO2 and harmful gases are very important ...
my house has no garage ... just a basement ...
- JohnB.
You're not allowed to have a gas range in your home?
LMWDP 267
huhLeBaroudeur wrote:Hello
what is that, as if you want to roast in your home without a vent...?
gas just needs adquate fresh air supply for oxygen and an exhaust.
LMWDP #483
Hello
I do not know if it is not to be recommended or .. prohibited.
to use gas at home, we need special ventilation for the gaz sytem.
like a fireplace.
At the inlet for fresh air and at the outlet for gas.
like a fireplace.
Regis Quebec
Use of a propane cylinder inside a building
Article: 6.7.3 of CSA B149.2-10
Subject: propane cylinder inside a building
Objective: to facilitate the understanding of the various conditions regarding the use of a propane cylinder inside a building
Stakeholders concerned: gas contractors, building owners and traders (jewelers, denturists and laboratories)
Publication date: July 17, 1995
Updated: November 18, 2013
When using a propane cylinder inside a building, several conditions must be met, in accordance with the Propane Storage and Handling Code, CSA B149.2-10, which is included in the chapter II, Gas, of the Construction Code.
The use of a propane cylinder inside a building is accepted under the following conditions:
the cylinder can hold a maximum of 5 pounds of propane and must not be connected to any other
propane must not be used in a dwelling or a hospital, assistance or detention establishment according to Chapter I, Building, of the Construction Code
- JohnB.
Hopefully no one is roasting inside with the propane container in the dwelling. Definitely illegal around here. Ideally you would have the propane tank outside feeding the roaster inside just as you would set up a gas range. Roaster would have to be vented to the outside also. Even if you use an electric roaster you still need to vent the smoke/fumes to the outside.
LMWDP 267
- Almico
I use my Cormorant in the garage, but if I didn't have that I would not hesitate to use it in the house with a propane tank. It has a 4" flexible duct that I would put in a window. That would evacuate most the coffee smoke as well as carbon dioxide from the flame.
Even with an electric roaster, you still need to find a way to get rid of the smoke.
- JohnB.
I do all my roasting with the Cormorant in my house but the propane tank is outside & the roaster is vented to the outside. I'm also located in the country with no close neighbors. If you are in town or have a neighbor close you might be limited as to what you could stick in an open window.
LMWDP 267
