Quest M3s Thermocouples - Page 3
I used the thermocouples sold by Sweet Maria's on my Quest. I believe these came from Molly. They are thin but you can adjust your roasting software to filter the noise and hence get a smoother curve.
Does anybody in Europe is using Quest m3s with MET probe, and can tell me what exact probe is that? Can i find somewhere ready to use one, with threading that fits MET position?
cheers!
cheers!
I placed an order through a local source, MillCity Roaster, and their working great. Thanks to jammin, in post #7 for the source.Beanz wrote:The thread is M4 x 0.7 There are usually plenty of local thermocouple manufacturers who can make one for you at a sensible price. I used a standard 1/16" dia probe and had them make it 3 inches long. If you cannot find anyone locally PM me and I will give you contact details for the company I used
<image>
Thanks for the info guys. Looks like i need to work without MET for a while Before I will find some solution in Europe, since importing a probe from Australia is abit overkill
How are those Thermocouples working out for you? I'm trying to decide between the ones offered by Coffee Shrub vs. the Mill City ones. It looks like the MC ones can be easily removed by loosening the compression nuts. My plan is to have two of them, one in the BT hole and the other in the ET hole. Would appreciate your thoughts. Thanks.roasterman wrote:I placed an order through a local source, MillCity Roaster, and their working great. Thanks to jammin, in post #7 for the source.
I'm still using them. I like them. Since I've upgraded to the smaller diameter they respond faster in the TC4.
Thanks for the quick reply. So they mount easily into the existing holes with no problem? And can they be easily removed by easing the pressure on the compression nut and simply pulling them out?
Yes, they just screw in. Then there's a little nut you screw on it (on the inside of the roaster.) This keeps the thermocouple from unscrewing.
