New 1lb roaster
- redbone
- redbone (original poster)
Thanks Evan, looks quite robust and not lacking anything despite its small stature.
* Is that a rear gas hook up ?
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Sure looks like it.redbone wrote:* Is that a rear gas hook up ?
LMWDP #581 .......... May your roasts, grinds, and pulls be the best!
I would expect it to be since most of them are NG or propane.
That does look like a gas 500 gram roaster from Mill City Roasters. (https://millcityroasters.com/shop/coffe ... e-roaster/)
I wonder why the roaster is not connected to any exhaust venting.
P.S. Up until recently, the model number for the 500 gram roaster manufactured by North Coffee Equipment and distributed by Mill City Roasters was TJ-066, where the "TJ" stood for "Taiwan Joy". Recently they changed the prefix in the model numbers from "TJ" to "NC", where the "NC" stands for "North Coffee"...
- jammin
^they would really benefit from a Parker needle valve. The stock ball valve is very touchy
- millcityroasters
We went with the full pass through ball valve for better low pressure performance. Now that we've reworked the gas train, needle valves are standard.
- FotonDrv
If you look behind the roaster on the wall you can see the black iron pipe with a reducer bell headed to behind the roaster. It is also going to all the places gas might be needed.Tonefish wrote:Sure looks like it.
