My "new" 5kg Turkish roaster has arrived - Page 18
- Almico (original poster)
This was working before, all of a sudden it is not.
In Artisan I check Events>Config>Snap so I can select where on the X-Axis my gas and damper values go.
On the Bottom tab I have values selected:
When I click the Gas 100 button it should put G100 on the 170* X-axis line and the label should be G-100.
When I click Damper 25 it should put a D-25% on the 70* line.
It was doing this just fine before. Then I closed and reopened Artisan and this is what it is doing:
I just restarted Artisan again, clicked Start>Gas 100 & Damper 25% and it displayed correctly on the graph, and the Gas slider shows 100, but the Damper slider shows 70, which is the X-Axis line where it is located, not the 25% that it is labeled.
- jammin
A couple questions:
What size BT probe do you have & where is located?
What kind of airflow adjustment do you have & how does it work? I see you have it labeled as damper but was curious if you could eleborate on your experience with it so far.
- CarefreeBuzzBuzz
Looks like the Damper is 25 cause the button was pushed. Can't really use both Dampers and Buttons best I know. If you use sliders whatever it is set at when you Charge will be an event. I far prefer sliders.
BT probe is under the site glass. ET is above the trier.jammin wrote:A couple questions:
I do not have a variable speed fan. Just a five position damper on the exhaust tube.
- jammin
i outlined this 3 weeks ago but it was met with opposition.Almico wrote:Fixed it. I pulled out the pilot/TC assembly and moved the TC closer to the burners.
Not sure why. I guess you still need to make sure the safety kicks off before the room fills with propane!
But it seems like an easy calibration move to me.
- jammin
what do you mean by thisAlmico wrote:Not sure why. I guess you still need to make sure the safety kicks off before the room fills with propane .
I guess if you turn the gas down low enough and the flame fluffs out, but the gas is still flowing a little, without the safety cut off you could get a pool of propane on the floor. If the TC was almost touching the metal burner, it might stay hot enough not to trigger the safety for a little while.
