Measuring air flow (pressure) with Phidgets gage displayed in Artisan - Page 3
- CarefreeBuzzBuzz
Did you try the dialog box I highlighted above for you?samtsai5212 wrote:I just added an extra device ,chose phidgets IO and checked the LCD. The readings in the LCD were different from those In the phidgets contrl panel and didn't syncronize with the air knob change . I did test switching the air knob and the readings in the phidget control changed accordingly. So I was sure I wired correctly. I have no idea if the the phidgets 1013 was supported by Artisan or what else I should do to get the air pressures readings.
- CarefreeBuzzBuzz
I am not sure but since it mentions your devices why not check some boxes and see what happens to start.
- CarefreeBuzzBuzz
Susan thanks for showing these images.SJM wrote:These might help
<image>
<image>
<image>
I no longer have this rig, so I can't be much help, but that will show how the probes were installed and the Artisan settings that were used.
