EBay Burkert Digital Control Valve - Page 7
The French Dude
Postby The French Dude » Jan 17, 2019, 1:29 pm
The 2.6 High limit control links seems to be broken.
Moreover I have some issues to dissasemble the controler. Once the screw removed the box don't want to separate. Did you had the same?
Edit: Problem solved I was affraid to broke something.
Almico
Postby Almico » Jan 18, 2019, 1:32 pm
Now that I have my Surface Go Touch screen to run Artisan, it would be cool to have it control the roaster as well.
I purchased one of these Burkert control valves when the price was too good to pass up. I also have a 3-phase motor (& VFD) that I was going to use for the drum RPM, but it might be better suited for the air, since all I have is a damper.
If I could get Artisan to control the gas valve and speed of the air while I'm pushing the buttons on my touch screen...I'd be the coolest coffee roaster on my street.
OldNuc
Postby OldNuc » Jan 18, 2019, 2:09 pm
The gas is probably controllable by controlling on the pressure downstream of the control valve and the same for air pressure downstream of the control device. These could be either straight pressure or differential pressure from a pitot tube.
baldheadracing
Postby baldheadracing » Jan 25, 2019, 9:17 pm
Quick update:
- installation mostly complete.
- in the docs, valve installation is "As required, preferably with actuator in upright position" Read that as, "Install in an upright position."
What I'm interested in is my worst espresso being fantastic - James Hoffmann
The French Dude
Postby The French Dude » Jan 28, 2019, 11:13 pm
I guess you control the vavle with the small box on the left.
So what is the pid for?
THX
baldheadracing
Postby baldheadracing » replying to The French Dude » Jan 29, 2019, 12:10 am
At the moment, I'm using the PID as a simple on-off control, connected to a thermocouple in the chaff collector. If the thermocouple gets too hot, then the PID cuts power to the Burkert, shutting off the gas.
The big red button switch on the side of the box also cuts power to the valve. Not visible is the regular on/off switch for the box, PID, and the valve. The visible toggle switch selects either using the computer or the knob for control.
(There are also a separate electrical/master kill switch and manual gas turn-off located a few feet away from the roaster.)
Chert
Postby Chert » replying to baldheadracing » Mar 21, 2019, 1:16 am
A
I am curious for an update on how you are using the Burkert.
baldheadracing
Postby baldheadracing » Mar 21, 2019, 12:20 pm
Chert wrote:I am curious for an update on how you are using the Burkert.
Not much of an update - I do annual maintenance in February, when it is too cold for me to comfortably roast. However, I ended up having to travel quite a bit so the roaster is still in pieces.
