Brainstorming theoretical fluid bed build - Page 2
Whoah!
Can't wait to watch this come together.
Is it getting hot in here or is it just all that stainless steel. You know what most people don't make, a quiet roaster. Maybe keep that in mind...
? As far as fan noise?crunchybean wrote: You know what most people don't make, a quiet roaster. Maybe keep that in mind...
Fan motor noise is no.1, after that is the beans sloshing around. I'm not sure if there are motors made to be quiet and long lasting. But I do know you can build a plexiglass container for noise reduction at least around the chamber. Also what level of portability for your machine did you have in mind? Maybe think about where it's home in your home it is going to be, and how you are going to filter or vent the machine (going outside).
I have two ideas. one is a Heavy base, thing is a bit tippy. possibly a converted old 1/4 keg. the fan motor inside with foam lining the keg should keep some noise down. The other idea is to have the fan in the basement and the roaster wall mounted on the back porch(semi enclosed). would be easy to "plumb" the exhaust outside and the fan being in the basement would all but eliminate fan noise during roasting. beans hitting the glass I haven't thought about yet.
Very interested in the parts list... are those home brewing piping/fittings?
Looks nice!
I am also interested which parts you ordered from stilldragon.eu
Which heating elements are those? Do you plan to use both?
