Best roasting accessory
CarefreeBuzzBuzz
#1: Post by CarefreeBuzzBuzz »
One of my most often used accessories is a bean scoop which used to be harder to find and 1/3 more than you can now get on Amazon.
https://www.amazon.com/Rattleware-Scale ... th=1&psc=1
What do you find useful?
Artisan.Plus User-
Artisan Quick Start Guide
http://bit.ly/ArtisanQuickStart
yakster
#2: Post by yakster »
My Harbor Freight funnel tray for filling canning jars, filling the roaster, and inspecting beans for defects.
https://www.harborfreight.com/easy-sort ... 37081.html
-Chris
LMWDP # 272
baldheadracing
#3: Post by baldheadracing »
Small Shop-Vac :mrgreen:
mkane
#4: Post by mkane »
Definitively, Shop-Vac
Tonefish
#5: Post by Tonefish »
Since the trier hole on a small roaster can really shock the drum air temperature (per thermocouple) I use a small, shallow, stainless steel measure cup to drop trier beans into so that I never have to remove the trier and open it's gaping hole. After smelling I dump them back into the hopper which is downstream of the drum airflow so no amount of trying shocks the drum air.
Of course, the shop vac is a must as is the scale and a sorting tray for both before and after roasting.
LMWDP #581 .......... May your roasts, grinds, and pulls be the best!
★ Helpful
keno
#6: Post by keno »
CarefreeBuzzBuzz wrote:One of my most often used accessories is a bean scoop which used to be harder to find and 1/3 more than you can now get on Amazon.
+1 on the Rattleware bean scoop, fantastic for filling bags.
cai42
#7: Post by cai42 »
Greetings,
I use a Ball canning funnel to fill vacuum bags and Mason jars with roasted beans.. Six dollars on Amazon.
EddyQ
#8: Post by EddyQ »
Deli containers with lids. Lots of them!
https://www.webstaurantstore.com/search ... iners.html
For multiple back to back roasting, I weight and store green beans in them with masking tape labels. Then roast and pour the roasted coffee into them. Bag or put in jars later. Note: I would not recommend leaving roasted coffee in these for more than a day.
The key is to get the size where the biggest batch of roasted coffee (fully expanded) fits with a little margin.
LMWDP #671
★ Helpful
Nunas
#9: Post by Nunas »
A funnel made from a rolled piece of heavy paper, because my Quest has no charging funnel and I've been too lazy to make anything more permanent :oops:
A Kil-A-Watt. I resisted this for the longest time, thinking it was a needless frill, but have to admit that it makes adjusting the heaters to just the right spot much easier than using the analogue meter on the Quest.
A large, slotted colander (pinched from the kitchen when I roast). After the beans have cooled for a couple of minutes, I put them in the colander and swirl, sometimes agitating them with my fingers too. This removes any chaff that has adhered to the finished roast. Test: grab some chaff and put it in your mouth--roll it around a bit--taste good--no! That's why I do this extra step :wink:
yakster
#10: Post by yakster »
+1 for the Kill-A-Watt, and if you have an Aeropress you have a pretty good funnel already.
I just bought a large spouted plastic measuring cup from Goodwill for $2 that works great for weighing the greens and roasted coffee and for pouring the green coffee into my bullet roaster. My previous bowl was a bit too small to hold my higher-capacity roasted coffee for weighing and didn't have a spout so I needed to pour the green coffee into my sorting tray before loading my coffee roaster.
-Chris
LMWDP # 272
Post Reply
