Artisan readings connection with Mastech MS6514
Andres0881
Postby Andres0881 » Jan 09, 2019, 3:23 pm
Hello everybody,
I really wish I can get help with this connectivity problem. I have a Quest roaster and I been trying to get my Artisan working with a Mastech MS6514; however, no graphs appear after I click ON to start the roast. what I have done so far:
- Download Mastech MS6514 drivers. This part is apparently working with the right drivers because of Thermometer Shortcut under COM3 shows readings.
- Connect Mastech MS6514 to my computer through the USB
- Hold the button that says PC Link at Mastech MS6514 for a few mins.
Under Artisan- Configuration I chose Devices/ Mastech MS6514 and check all the boxes for ET BT under Curves and LCDs.
So far I do not get any readings in my Artisan. Please let me know if I am missing any step in between or if Mastech MS6514 is not good to get connected to your computer. Thanks
Almico
Postby Almico » Jan 09, 2019, 4:56 pm
I know nothing about the Mastech, but on my MacBook Air, if I plug anything into any other USB port, my Phidget readings go away. I'm sure there is a way to reconfigure, but I do not know how.
MaKoMo
Postby MaKoMo » Jan 09, 2019, 5:03 pm
Andres0881 wrote:Under Artisan- Configuration I chose Devices/ Mastech MS6514 and check all the boxes for ET BT under Curves and LCDs.
Did you tell Artisan on which serial port it should request data from? Select COM3 from the serial port popup under menu Config >> Port, first tab.
MaKoMo
Postby MaKoMo » Jan 09, 2019, 5:05 pm
Almico wrote:I know nothing about the Mastech, but on my MacBook Air, if I plug anything into any other USB port, my Phidget readings go away. I'm sure there is a way to reconfigure, but I do not know how.
That might actually be a power problem. USB ports are limited in the power they provide and most connected devices consume some. At one point the USB hardware decides to switch of a port. This is true for some machines. Had issues with an MacBook Air too. Not with another very old MBA nor a MacBook 12" 2015 nor a current MBP. On that MBA I could re-activate those USB ports only via a reboot. There was no software trick I could find to resolve this.
Almico
Postby Almico » replying to MaKoMo » Jan 09, 2019, 5:09 pm
Mine reactivates as soon as I remove the other USP device. In this case it was a Brother printer. Sometimes my WiFi in the garage is weak so it's nice to just be able to plug in the WiFi printer direct. But I wait until after the roast.
Andres0881
Postby Andres0881 » Jan 09, 2019, 5:21 pm
MaKoMo wrote:Did you tell Artisan on which serial port it should request data from? Select COM3 from the serial port popup under menu Config >> Port, first tab.
Yes I did. Only option available is COM3
radityagpp
Postby radityagpp » Feb 11, 2019, 8:51 am
maybe after you plug usb to comp, you not press and hold "setup" on the mastech, hold till you see text "usb" on display mastech
edschlukebir
Postby edschlukebir » Feb 17, 2019, 10:04 pm
I don't remember how I figured this out, but I had a similar issue getting my macbook and the mastech to talk to each other. I just looked at my settings, and its set on com 5
hankua
Postby hankua » Feb 19, 2019, 6:27 am
Andres0881 wrote:Yes I did. Only option available is COM3
I would delete the drivers and reinstall the latest version, and download an older version of Artisan. And also try it out on another computer just to verify the issue. I recently replaced a Mastech that quit working after two years, different problem than yours but it's possible the meter is the culprit.
