Artisan on a 800x480 touch screen?
- greencardigan
Hi,
I might try running Artisan on a Rasberry Pi and am trying to decide what touhcscreen to get.
Does anyone know if Artisan would be usable on the official Rasberry Pi 7" 800x480 resolution touchscreen? There are higher resolution screens out there but they start getting a bit pricey.
Any recommendations for other reasonably priced screens also welcomed.
Thanks.
Thanks.
- MaKoMo
Brad,
it runs on the 7" official touchpad and the Artisan team tries to keep the essential dialogs in a layout to fit that screen as minimal requirement. However, screen estate is tight on the 7". You want to run Artisan in Full Screen mode on that screen, hide sliders and buttons if not needed, and potentially use the zoom follow feature. The nice thing is that the whole device (incl. the RPi) is so small and you do not need a laptop anymore. You can configure the RPi to store the profiles on DropBox and then do post processing of those on your laptop later.
LMWDP #360, https://artisan-scope.org
- Almico
Can I run Artisan on a 10" Raspberry Pi touchscreen with a Phidget 1048?
- Almico
- baldheadracing
<deleted, irrelevant>
- CarefreeBuzzBuzz
Alan,
On Events>Config, right side where there is a check box Snap - is that unchecked?
- MaKoMo
Well, a little off topic ...Almico wrote:Yay!
Another question: Are the events permanently tied to the x-axis values? When I have my X limits set to 50-450 I get this:
Is there a layman's way of getting the events to display with a 150-450 temp range?
Events have by default their own axis which are only indicated by those horizontal bars below the first phase mark. If you move the lower limit of the first phase up (within the Phases dialog), those bars will follow. However, there is also an option to have the events aligned by value to the y-axis if the flag "Snap" is ticked in the Events dialog.
- Almico
