Artisan - Header
- chuckcoffee
I had the same issue. My solution was to extend the horizontal axis by 4 minutes. Now the box shows in an unused area.
Curly
Curly
- CarefreeBuzzBuzz
I am guessing you are using older versions of the program. If you aren't on 2.1.2 please upgrade and let us know.
https://github.com/artisan-roaster-scop ... History.md
UI: reworked statistic summary featuring a configurable line length
- chuckcoffee (original poster)
- CarefreeBuzzBuzz
Also go into Config>Stats and change the Character per line and see if that helps, leaving your sampling notes.
CarefreeBuzzBuzz
Ok, that helped. Set it to 25 from 30. Its clipped some text but lets me see the drop. Do you know if this is something that is planned to allow same behavior as the legend that you can drag its position? Would be cool if you could have option to automatically display your sampling settings.Also go into Config>Stats and change the Character per line and see if that helps, leaving your sampling notes.
- CarefreeBuzzBuzz
- zeece
The preferred method is to click (checked) Config>Axes>Auto. Artisan will now make the necessary adjustments automatically. The alternative method is to set the time axis manually so that it is long enough to accommodate the statistics summary.
- Chert
I just update and shoved a donation toward the artisan team.
LMWDP #198
