Artisan beta roasting software available - Page 3
- Whale
By the way would you rather get feedback by PM, e-mail or posts?
Being completely inept and programming challenged makes me a good software glitch finder. If a software is made fool proof from me it usually is fool proof to everyone.
LMWDP #330
Be thankful for the small mercies in life.
- MaKoMo
There is an issue tracker at
<http://code.google.com/p/artisan/issues/list>
Everyone can add issues there. Using this makes it easy to track issues (for you and us).
M.
M.
LMWDP #360, https://artisan-scope.org
- benm5678
I noticed it too on my hh506ra, sometimes the display will have dashes, and when my logger software reads it, it gets a very high #. Sometimes, I think it happens also with no visible problem on the logger display.
To help eliminate this, I changed the logging tool I use to ignore unrealistic numbers outside the graph range, and try again... eventually after a few tries, it will display it (it's set to sample every 1 sec, so don't lose that much if it skips a few reads). This made the graphed data clean again. It's probably something on the hh506ra end...
- MaKoMo
Yes I observed that too on my HH506RA in connection with artisan (I guess this behavior is due to the combination of the optical connection with a serial protocol used without soft/hardware flow control). We will "enhance" the next version of artisan such that those outliners are ignored and you get smooth graphs.
M.
M.
Any chance you will be adding support for the Omega HH802U ?
- Carneiro
I got some weird readings from the Arduino running the Artisan software while the serial monitor from Arduino software was running - the serial port was open by other software. Even after I closed the monitor I had the problem.
Do you think you could have the serial port open and not closed by some software, and then the driver could be messing some buffer?
Rafael, I've done some code for the Arduino + TC4 shield to reply to any byte sent on the serial line. But Arduino resets after the serial is opened (it's possible to workaround this but it's a little bit messy). So I changed the Artisan just for testing opening the port right when the software starts and not closing it. I should think about it - maybe open the port the first time the ArduinoTC4temperature function run and keep it open.
Do you have any plan on making the software more modular?
Márcio.
Márcio.
- Arpi (original poster)
It looks the same as the HH806 and it may work already (don't know). The Omega software has the same product number as the HH806.OkcEspresso wrote:Any chance you will be adding support for the Omega HH802U ?
Cheers
PS: I would also consider the CENTER309 (has 9V power adapter, 4 thermocouples, good price, nice build quality, better manual and software), as it appears that people are reporting trouble with the Omegas.
To make the arduino run with artisan you would need to spawn a thread, you could use a buffer or a signal. See QThread.Carneiro wrote: Do you think you could have the serial port open and not closed by some software, and then the driver could be messing some buffer?
Márcio.
Cheers
We own it so I'll give it a shot and report back.Arpi wrote:It looks the same as the HH806 and it may work already (don't know). The Omega software has the same product number as the HH806.
Cheers
Yep, that worked.
So it probably works for the whole 800 series. Anyone else have another model?
