Artisan 1.3.1 released
- CarefreeBuzzBuzz
Changes listed below. The documentation has been renamed Quick Start Guide and is now part of
https://artisan-scope.org
Don't forget to donate to Marko as without him we wouldn't have Artisan.
New Features
adds Cmd-S as shortcut for "Save As" (#194)
remembers fullscreen mode over restarts (#199)
allows to insert a custom event button line before the selected one by clicking Add
adds insert action to the alarm table to add an alarm line before the selected one
adds support for the new Fuji PID PXF
adds PXF variant of Sedona Elite and Phoenix machine configurations
adds copy as tab delimited text action for data tables
Changes
restricts the "time-to" display introduced in v1.3 to the temperature mode rendering the percentage mode again as in v1.2 (#196)
all hundredths not only thenth in roast properties weight and volume (#198)
requires to tick the Control flag to activate the 'Control' button and the PID features also for the case of the TC4 with PID Firmware as for the Fuji PIDs (#205)
events created by sliders now put the values translated using the sliders offset and factor to the event descriptions together with a unit prefix
started internal code modularisation resulting in lower memory demand in most cases
removed support for Qt4
updates to pymodbus 1.5.2 for better error handling on noisy lines
increase width of phases LCDs to hold one more digit and update tooltip
improves slider release action
Bug Fixes
ensures that the matplotlib font cache is used on Linux (#178)
fixes an error that could occur on deleting an event button definition (#179)
ensures proper persistance of the "Descr." checkbox state of the events dialog over restarts (#180)
fixes a communication issue with Aillio Bullet R1 roasters running a newer firmware (#188)
fixes a build error in v1.3 that caused Artisan to crash on opening a file selector (#182,#187,#188)
ensures that decimals in curve width are properly handled (#186)
fixes a regression that disallowed for negative event button values (#191)
fixes an unhandled exception in the alarm processing (#192)
fixes a rare case were the first event listed in roasting reports got duplicated (#195)
fixes Phidgets pulses that never latched back
fixes background title colors
fixes a problem setting extra device colors
fixes reveal of hidden buttons when changing Config>Colors
fixes some redraw hickups in fullscreen mode on OS X
fixes wrong character encoding of dates in statistic summaries
https://github.com/artisan-roaster-scop ... History.md
New Features
Changes
Bug Fixes
- Supporter ❤
I'm having issues reading the temperature of my BC roaster, bluetooth or wired USB into the Artisan software. I had to switch to my TC4 to be able to roast. Anybody else having issues with the new release?
- felyko
Was it working on 1.3.0?blondica73 wrote:I'm having issues reading the temperature of my BC roaster, bluetooth or wired USB into the Artisan software. I had to switch to my TC4 for be able to roast. Anybody else having issues with the new release?
- Supporter ❤
Yes. I wonder if it is the 1.3.1 version or my Mac update. If anybody else is using a BC Roaster, I would love to hear from them.
- felyko
There was a big change with pymodbus which BC roasters use. Can you try to see if there's any modbus configuration that works? (Config > Ports > Modbus)
- MaKoMo
Dear Christian,blondica73 wrote:Yes. I wonder if it is the 1.3.1 version or my Mac update. If anybody else is using a BC Roaster, I would love to hear from them.
could you open the MODBUS tab (menu Config >> Port, 3rd tab) and verify that both little-endian flags (bytes and words) are not ticked? Please report if this resolves your issue.
LMWDP #360, https://artisan-scope.org
- Supporter ❤
The "words" flag was selected. As soon as I un-selected it, I was able to read the correct temp via MODBUS on the BC Roaster. Thank you, Marko.
- MaKoMo
Thanks for the confirmation! We will fix the BC Roaster setup accordingly. Sorry for the troubles.
- CarefreeBuzzBuzz (original poster)
For anyone else looking an updated build has been posted and documented here:
https://artisan-scope.org/machines/bc/
Just downloaded the Mac version (artisan-mac-1.3.1.dmg), but am getting Artisan 1.3.0 (ca3c5f1) per the about window (and doesn't show the new Save As shortcut
Dan
Dan
Dan Miller
Gato Diablo Specialty Coffee Roasters
Cape Vincent, NY
Cape Vincent, NY
