Would you replace these burrs?
- BaristaBoy E61
Are you referring to the screw threads or just the screw heads being stripped?
The burrs don't look like they're in ruff shape from what I'm seeing, unless I'm missing something.
How does your espresso tastes with this grinder & burrs; is it slow to grind?
- yakster
It looks like the burr was chipped above the lower left mounting screw. Not sure how that would affect things.
-Chris
LMWDP # 272
LMWDP # 272
- cafeIKE
As long as the burr is not cracked, the missing bit has zero effect. It's in the crushing region and no coffee uses chunks that big
How much coffee has been through them?
Ian's Coffee Stuff
Same here, wouldn't replace. As it's on the inside (breakng part) it shouldn't have any effect on grind quality. If it where on the outer edge (grinding part) then it would definitely affect grinding.
And do look if it didn't cause cracks in the metal itself. If chunks of metal will come off it'll seize and ruin the burrs completely and potentially burn the motor and damage the axle and then you can throw the whole grinder away.
Nothing wrong with the burrs and nothing is chipped out of them, it just happens to be the way the hole is in relation to the cut of the burr. In fact they look quite new to me.
I would not. Yeah, the screws are not perfect, but that's a case of the tail wagging the dog.
It's a bit hard to tell. I see some imperfection where the others have said close to the screw on the lower left. In the outer cutting region, I can't tell if there's a chip or it could be a coffee/other visible particle. Maybe wipe down the burrs, vacuum, and take another look. In my opinion, the burrs look fine.
they look like new to me, why not check alignment and if OK just go with the flow. If alignment needs adjusting get a set of new screws and replace them while adjusting alignment?
LMWDP #483
