Why more than 1 grinder in home? - Page 4
Two espresso grinders on bar currently, one for blends, one for single origin varietals. I like having both available at any given time. Used to have to do decaf alongside regular.
I also have one travel grinder for espresso and another for French press.
Have one manual grinder for backup in the house...in case the power goes out
LMWDP #748
- DJL
Are you a Fender or a Gibson man?leonelbego wrote:I truly get it my main hobby is playing guitar, I got 12 different guitars :-/ haha
DJL wrote:Are you a Fender or a Gibson man?
haha
Defo not a Gibson man
I play both, electrics and acoustics guitars, mainly acoustics, and there I am a BIG fan of "Boutique" guitars rathen than the main stream like Martin or Taylor or so... So, I do have a couple of Santa Cruz Guitars, Froggy bottoms, etc... and for electrics I got Fender Strats and Nik Huber....
are you a guitar player as well?
Leo
Yes, if I had the money and room, I'd probably have more than one grinder.
I have the Mazzer Robur with the Doser, I love it. The threaded top adjuster has the advantage of being able to dial in anything you want.
It isn't for everybody and the Robur has it's adherents and detractors. I did have the M4D Macap before that and I found that the worm adjustment was good except when you wanted to do a different grind such as Turkish or for plunger coffee. The Robur is good for that as you can go back to the same setting except of course it does retain some grounds.
In pursuit of the perfect grinder is why many people have more than one...as there is no perfect grinder.
I do appreciate the design of different grinders. I think I am particularly impressed with Ceado grinders which don't have resellers here in Australia. Eureka have interesting grinders but I like the design of Mazzer and Ceado better although both are very different.
Grant
Grant
LOL!!michael wrote:I keep my robur e after I got the monolith flat because the robur is too heavy to get off the counter
on a more serious note, we do the occasional robur monolith taste off
How do they compare?
different
with the robur you get a smoother, blended flavor
the monolith flat SSP highlights and separates more of the individual flavors in the coffee
I would do this more often but the problem is that it sometimes takes a lot of coffee to dial in the robur; if youre not using the same coffee as the prior shot (which always seems to be the case), seems like it takes 2 additional shots to see the results of a grind adjustment; if you don't hit it right the on the first adjustment, with these 12 oz bags before you know it the bag is moving towards the second half
I also have a kony e at another location; similar taste profile to the robur; to avoid the dialing in waste I tend to use a lot of the same beans
could be the robur e worked better at home when everyone was selling lbs
you got a MAX in the last offering, right
Wow...another guitar player that likes Nik's guitars. rofl. FWIW..not only is he one of the finest luthiers in the world, he's also a helluva nice guy. My Redwood is a korina body and neck with a Brazilian fretboard. I have owned a ton of his guitars and there is nothing like them. I also have a Collings acoustic with Braz body and sitka top...I don't even want to know how much that guitar would cost to build today. I would probably need to sell my house.haha
Leo
Bock on topic...I am sure it has already been said but the bottom line is that different grinders do different things well. I have yet to encounter a single grinder that can handle all of my different brew methods. I brew espresso, chemex, V60, auto drip, and French press. I need at least a couple of grinders to make that work well.
yeah, I do agree, Nik Huber is AMAZING. his quality is out of this world..... having said that, I recently also purchased a B&G Step Sister Private with ziricote wood that is by far the most amazing electric I have tried in my life, in every sense! Period! haha!
Regarding the second grinder, you all convinced me, and I bought already (yesterday) the second one, I bought a Etzinger Etzmax Light, I will be using that one for my Chemex and French Press etc... lets see.... I am still a massive fan of my Ceado Single Dose E37SD
I wouldn't touch the Etzinger with a barge pole it is just a grossly overpriced Sette.
On Coffeesnobs, the bubble,burst on that one. It is just a cheap plastic grinder.
