Why more than 1 grinder in home? - Page 2
leonelbego
Supporter
#11: Post by leonelbego »
Quester wrote:Part of it for some of us is an outgrowth of being an enthusiast. Coffee is my primary hobby, so it's natural to invest time, energy, and resources. Do I really need a refractometer? No. But it like it!
I truly get it :) my main hobby is playing guitar, I got 12 different guitars :-/ haha
mohninme
Supporter
#12: Post by mohninme »
My choice to have and use two grinders is very simple. My wife and I have different preferences and making espresso is something I like to experiment with. I use one grinder with a hopper and it gets the same beans in it day in and day out. Its the "house brew" grinder... so to speak. The other grinder is for experimentation and I am regularly changing coffees and adjusting settings. Trying to do this with one grinder just doesn't work.
Michael
sosha
#13: Post by sosha »
To keep it simple.
My Niche is dialed in for espresso, and I don't want to mess with it. Single dosing is my preferred method for espresso.
I have a Vario for FP. 2 grinders makes it idiotproof.
LMWDP #440
lrj13
#14: Post by lrj13 »
leonelbego wrote:Hi Elliot,
Thank you very much! Yes, the Ceado E37SD is amazing, perfect for single dosing!
Also, thank you for your comment :) getting a second espresso machine is a big step ;) May I kindly ask why? Is it an upgrade or to have two different machines in home? Do you it professionally?
Leo
I echo Leo's sentiments with the different brew methods.
I used to only have the T-64 grinder for all brew methods (Turkish, espresso, chemex, Kono, roast sample, French press) etc etc and with the worm gear (which is brilliant for dialing in for espresso) it was a mahoosive pain to go from espresso to drip to press and back again.
I got a baratza for brew grinding and haven't looked back.
I was too stubborn before but now I'm glad I bought a second grinder. Not everyone can do that but if you brew all kinds of methods, it's worth it.
I hope that helps.
poco ma buono
La Macinazione, La Miscela, La Macchina, La Mano
shawndo
Supporter ◈
#15: Post by shawndo »
Some of us just have problems :D
My name is Shawn
Darmok and Jalad at Tanagra
leonelbego
Supporter
#16: Post by leonelbego »
lrj13 wrote: I echo Leo's sentiments with the different brew methods.
I hope that helps.
Thank you! It makes a lot of sense :) even to the point that now you are making me consider getting a second easier grinder for my wife's Chemex! Currently we are using the Ceado E37SD for my Espressos and for hers Chemex and is a really pain to go back and forth with the settings!
Hmmmmmm!
TheMadTamper
#17: Post by TheMadTamper »
I have 3 active grinders currently. I use the hopper and thus have 3 sets of beans. My bulk "house blend" that I use for the morning to-go drinks, my active "whatever new blend/SO I'm using now" for evenings/weekends. And my decaf grinder. If I get into home roasting at any point, I'll likely re-add one of my sidelined grinders into the fold again as well.
LMWDP #642
Quester
#18: Post by Quester »
leonelbego wrote:Thank you! It makes a lot of sense :) even to the point that now you are making me consider getting a second easier grinder for my wife's Chemex! Currently we are using the Ceado E37SD for my Espressos and for hers Chemex and is a really pain to go back and forth with the settings!
Hmmmmmm!
For $250, the Virtuoso is a decent brew grinder. Mine was much better than the Breville Smartgrinder I had before the Virtuoso.
mhpchan
#19: Post by mhpchan »
I'm actually in the same boat of considering a 2nd grinder too. My current grinder is a Ceado E37S but it's a pain to switch between caffeinated for daytime and decaf for night time. Tried to do single-dosing on the Ceado but it's more time consuming and the E37S has around 0.5g if retention. Hence, considering a "cheaper" Baratza Sette 270Wi for decaf only.
trapperkeeper
#20: Post by trapperkeeper »
I'm down to 2 that get regular use - 1 espresso, 1 aeropress/drip/camping/power goes out. Used to have 2 K10's and a E8 just for espresso - 2 regular beans and 1 decaf :)
LMWDP #600
